    RC Racer alexander111222's Avatar
    Oct 2014
    denmark
    117
    e revo tommorow!
    so my e revo brushless #56087-3 is coming in the mail in about 7 to 17 hours and i just wanted to know how to do the slipper clutch adjusting the manuel didnt explain it in a way i competly understud. btw sorry for the english typing with not light is hard lol #soexecited
    RC Racer Pro2A's Avatar
    Apr 2016
    Long Island NY
    245
    Congratulations on your new e revo!!!
    I tighten my slipper clutch all the way, (until it starts getting hard to turn) then back it off about 1/4 turn. That seems to work good for me
    RC Champion zoraduntov's Avatar
    Jan 2007
    California
    2,603
    congrats !
    They are a blast to drive
    Feb 2013
    Montreal, Canada
    5,590
    Awsome, congrats, you are going to love the erevo
    Have a look at this thread
    6s or 4s you need to start with 18/54 gearing.
    Slipper Clutch Break-In
    The E-Revo Brushless Edition’s slipper clutch requires a break-in procedure
    to ensure consistent operation with the extremely high power output of
    the included Castle Creations Mamba Monster brushless motor system. The
    slipper clutch has been adjusted to the correct initial setting for break-in.
    Follow these steps to ensure maximum performance and life from your
    slipper clutch:
    1. Make your first runs with the model using the stock gearing and 6- or
    7-cell NiMH packs, or 2S LiPo packs.
    2. Drive normally. The slipper clutch should slip momentarily when
    accelerating aggressively on high-traction surfaces (you will hear a
    whirring sound when the slipper clutch allows the spur gear to slip).
    3. If excessive slippage is noticed (slipping that lasts for more than 3
    seconds under hard acceleration), or the slipper clutch slips anytime
    the throttle is applied at any lever, stop driving immediately. Let the
    slipper clutch cool for 10-15 minutes. When the clutch is cool, test-drive
    the vehicle again. If you still experience excessive slippage, allow the
    slipper to cool once more, then tighten the slipper nut turn (turn the
    nut clockwise) and repeat the break-in process. Do not adjust the slipper
    clutch before it has cooled.
    4. Continue to run the vehicle and monitor slipper clutch performance as
    noted above, and readjust if necessary. When the run is complete, the
    slipper should be fully broken in.
    After break-in, the slipper clutch is ready for any type of driving, with any
    batteries up to 6S Lipo. Set the slipper clutch so it only slips for a moment
    (if at all) under hard acceleration in high-traction conditions. If excessive
    slippage is noticed, stop driving immediately. Continuing to drive with a
    loose slipper will cause damage to the slipper unit. You must let the slipper
    cool down to ambient temperature before tightening the slipper nut and
    resuming driving.
    Live life to the fullest
    Oct 2014
    denmark
    117
    thanks everyone and i know i will love it sadly it still hasent come the waiting is like torture lol
    Oct 2014
    denmark
    117
    btw jezza i am gonna be driving on 4s. when doing the slipper clucth break in should i use them or the stock batteries and if i use them should it be with the 18/54 gearing?
    Apr 2016
    Val-d'Or, Quebec, Canada
    85
    Quote Originally Posted by alexander111222 View Post
    From Jezza's post which I beleive is a quote from the manual you leave the gearing stock for the break-in. IUf you read the item #1 it clearly say you can use 2S LiPo packssssss (I emphasize on the "s") so you will be good if driving on 4S.
    Mine is in the mail also. The wait is killing me.
