Results 1 to 14 of 14
    Apr 2016
    Val-d'Or, Quebec, Canada
    85
    What is your "Before" and your "After" procedure to keep the E-Revo in top shape
    Hey guys. Tried to find something similar but couldn't.
    After I did a good run with me Revo I'm not entirely sure what should my routine be. I only have the Revo for a week and I'm trying to take good habits of "before" and "after" things to check.
    For instance, after my run I make sure there is nothing cracked and that the driveline is OK. I clean everything with air as much as I can, put my batteries on "storage mode" and call it a day. Should I pay more attention to something in particular?
    Prior to every run, I make sure my ESC respond correctly and same for the control, I make sure the fan is turning and then I go.
    Am I missing something ? Mind to share what you guys do before and after maybe I can pick a few things up from you guys.
    Thanks.
    RC Racer Frontline1985's Avatar
    Mar 2016
    Thousand Oaks, CA
    242
    I am doing pretty much the same things you are doing. Do a visual of everything. Check the wheel nuts are nice and tight and I make sure my batteries are balanced before I go out also.
    RC Racer C0BRAX's Avatar
    Feb 2016
    Colorado
    229
    Every couple of runs or so make sure the hubs are still snug. I'll check the mesh on the spur and pinion every so often as well.
    Happy Motoring!
    Feb 2013
    Montreal, Canada
    5,590
    Before I ran mine, I do a step check up
    1. All wheel nuts are tight; blanced etc
    2. Slipper Cltch has not loosened
    3. Underneat skids have all the screws in place.
    4. ll pushrod and rocker screws
    5. Wirings, all in good shape
    6. Motor amd esc do not move
    7. No crack on the bulks and chassis and all my drive shafts are all in good shape.
    8. Transmitter batteries still charged.
    Live life to the fullest
    Mar 2016
    Thousand Oaks, CA
    242
    Quote Originally Posted by Jezza View Post
    Yes I do these lol. Jezza you wrote it way better then my non helping post.
    Feb 2016
    582
    Before
    1. Are batteries charged?
    After
    2. Are batteries discharged?
    Runumhard till it breaks.
    RC Champion MaXXL's Avatar
    Nov 2015
    South Florida
    1,222
    ^^ Yup i just make sure to store my batteries at 3.85v per cell in a cool place. Thats it. Nothing else before or after unless i find something is broken or missing.
    10 RCs and counting 😅
    Nov 2015
    296
    I guess after you do this for awhile a lot of the list becomes subconscious routine if you prefer top performance.
    2. Find more body clips
    3. Transmitter batteries still charged
    4. Hip pack tool kit
    Apr 2016
    85
    Thanks guys I will keep an eye on what you suggest!
    Apr 2015
    286
    For me running in wet conditions pull wheel bearings and recoil after every wet run. Also clean transmission. And diffs if you are up to that much water. Blow out tires and reglue
    Mar 2016
    Thousand Oaks, CA
    242
    Make sure to check the yoke pins on the driveshafts. Mine were super loose after a couple outings.
    Apr 2016
    85
    Quote Originally Posted by Frontline1985 View Post
    Yep +1 on this I have eaten part of my bulkhead because a grub screw was coming out
    Sent from my SM-T700 using Tapatalk
    Nov 2015
    South Florida
    1,222
    ^^ +2 i use a little bit of CA on the threads and they havnt backed out since.
    RC Racer alexander111222's Avatar
    Oct 2014
    denmark
    117
    Quote Originally Posted by lgarceau View Post
    same hehe i have eaten so much of my front bulkhead because one grubscrew just kept getting loose
    be vewy vewy quiet the e revo is sleeping
