Results 1 to 38 of 38
    Apr 2016
    WORSE-TER, MA
    204
    First run on 3s Broken crap
    Unreal. You'd think the hobby would have got a little better by now.
    What's the strongest camber link I can get for this thing?
    I see these, but what balls do I need for them?
    Apr 2016
    36
    Those look like rustler xl5 replacement parts. If so, no balls. Shoulder screws.
    Sent from my XT1575 using Tapatalk
    N. Idaho... Da Sticks!
    7,690
    Looks like you just got a bad part there. Those 4mm turnbuckles are generally stronger, flex less and provide adjustability that those fixed links don't.
    RC Qualifier StampedeSwag13's Avatar
    Apr 2015
    544
    All parts will break, just get over it. 3s is where things will break. Thankfully you did not break something huge tho.
    and RC pilots say RC cars can't fly!
    RC Qualifier WonderMelon's Avatar
    Mar 2016
    Myerstown, Pennsylvania
    957
    Lol calm down mate! Don't downgrade if something breaks!
    Apr 2016
    WORSE-TER, MA
    204
    I could care less about adjustment. I don't race. I need something durable. I upgraded from stock, thinking it was going to be stronger. I don't even bash that hard.
    I've seen dudes with what I thought was aluminum versions of those RPM ones. Or was I seeing things?
    Is a Rustler XL5 the same chassis?
    Do the RPM's come with shoulder screws I wonder?
    RC Qualifier FROSTYEYE's Avatar
    Nov 2015
    NJ
    396
    I broke a ton of the traxxas 4 mm turnbuckles, I switched to Lunsford and haven't had a problem yet.
    http://www.lunsfordracing.com/mm5/me...de=TRUC-TRRVXL
    If it cant be broke, I'll break it.
    Apr 2016
    36
    Traxxas 3642 Attachment Screws https://www.amazon.com/dp/B0006MZRUK..._bNMoxbGT0W51C
    Comes in a 6 pack, without washers...
    You're gonna need 8 and washers.
    If you're screwing into metal you're gonna want loctite too.
    Apr 2016
    WORSE-TER, MA
    204
    Quote Originally Posted by FROSTYEYE View Post
    Cool, traxxas should just make the stock ones out of frign twigs.
    Apr 2016
    WORSE-TER, MA
    204
    So anybody using the RPM links? The Lunsford ones are probably the best but $40
    Mar 2016
    957
    Quote Originally Posted by knucklebrain View Post
    I'd not suggest the plastic ones mate, use metal and plastic. I never had problems
    Apr 2016
    WORSE-TER, MA
    204
    Wondering if I should just use the stock ones. They appear to be steel, not aluminum.
    Nov 2015
    NJ
    396
    Hahahaha, the traxxas ones are fine, I bought the Lunsfords because I drive fast and wreckless. Try hitting a curb at 30 or 40 mph with a real car, you'd be lucky to get away with only breaking a tie Rod.
    RC Qualifier Zamboniman808's Avatar
    Oct 2014
    Canada but now New Delhi
    942
    You can also go the route of just using 8-32 stainless threaded rod stock. You just have to cut it to size. $5 for a meter of it and you will have links for years. It's what we did for the wide mod on my son's p2de and it works great.
    Apr 2016
    24
    @ OP..Why complain..you monster truck people need to realize how much rolling mass that is protruding from the truck..your gonna break stuff..whats the first thing that break off of an airplane..same deal..
    Try going all billet suspension..and/or a closed course, without as many objects to hit..
    When the wheels are tucked in closer to the vehicle mass/body..then things are protected more, and stronger, because everything is shorter..don't blame the manufacturer for building a budget friendly vehicle..otherwise the vehicle would cost double+..
    SM-N910C Gold Note 4 (MM 6.0.1)
    Apr 2016
    WORSE-TER, MA
    204
    Quote Originally Posted by Zamboniman808 View Post
    Will the standard Traxxas ball ends fit?
    Jan 2016
    105
    When I got my Rustler I felt a bot disappointed because after the first 15 minutes of running it I broke 3 parts and it was down until I could get them replaced. Then I started reading a lot of RC forums and realized that out of the box MOST RC cars are built just like that....the come with parts that will break easily, especially when running 3S and above. Since my upgrades to certain aluminum and RPM parts I have not had that problem for months.
    Apr 2016
    24
    Quote Originally Posted by Randycandy View Post
    Exactly..
    Oct 2014
    942
    Yes, the long ones. Those are the ones that come on the vxl links.
    Aug 2007
    So Cal
    21,511
    RPM links rarely if ever break. They almost always end up bent and deformed from all the flexing they do though.
    Sent from my SM-N920T using Tapatalk
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    RC Racer A1ArmedToaster's Avatar
    Aug 2013
    Your Grandmother's Kitchen Counter
    183
    I've been using the RPM links for a few years and they hold up well
    Rustler VXL/ Merv (sold)/ Q32/ Ambush/ Kraton
    RC Qualifier timmey77's Avatar
    Nov 2014
    Vienna, austria
    476
    I'm not sure If I saw this correctly but to me it looks like youre using the blue aluminium turnbuckles? If you do switch to the steel ones
    RC Qualifier Swampthing's Avatar
    Houston, TX
    472
    Quote Originally Posted by timmey77 View Post
    I was going to say the same thing. The blue aluminum ones are weak. The stock steel ones from the VXL are much stronger...
    Rustler | MERV | Summit | Slash Ultimate | Slash
    Apr 2016
    WORSE-TER, MA
    204
    Already switched back to stock. The blue aluminum = USELESS
    Apr 2016
    WORSE-TER, MA
    204
    This thing just got a good solid beating. Bent my custom 1/8" thick motor guard guard and bend the aluminum STRC motor guard too. Guess I'm gonna have to make the thing out of steel.
    Mar 2016
    957
    Supports, you need to add supports for them mate
    Apr 2016
    WORSE-TER, MA
    204
    How do I do that?
    Jan 2010
    204
    Steel won't bend as easy, but will transfer the hit to the next weakest point. Either learn to land better or get a plastic rear bumper/guard that can absorb that energy.
    Arizona
    2,383
    Get a T-bone rear bumper. That will help a ton for the back.
    1 Slash 3 Rustys & visits with my old P4de/SC8
    Oct 2015
    6
    R these better than the Steel cambers or Turnbuckles. Also does Titanium rust?
    RC Qualifier CastleNewbie's Avatar
    May 2016
    297
    I would invest in some plasti dip and dip your plastic ones I did and I've never needed to ever replace any!! Just my opinion. It gives a lot of flex bu adds some weight.
    Mar 2016
    957
    Quote Originally Posted by Basicblaq View Post
    Titanium does not rust...
  33. #33
    20,529
    Quote Originally Posted by WonderMelon View Post
    ...below 1100F.
    Alt-248 on the number pad =
  34. #34
    Mar 2016
    957
    ...below 1100F.
    Wait it rusts? Huh LOL sorry I didn't know that.
  35. #35
    20,529
    At those temps, oxidation of the titanium alloy is the least of your worries.
  36. #36
    Nov 2015
    NJ
    396
    Much better than the steel, not sure about the rust, but all metal will rust I believe
  37. #37
    Apr 2016
    WORSE-TER, MA
    204
    Man my truck just slid down the street on the roof. I didn't know if it would ever stop. Sick of the street and baseball fields.
  38. #38
    Jan 2016
    549
    Mine did cartwheels I didn't know when it was going to stop. Lol
