Results 1 to 14 of 14
    May 2016
    76
    Advice/ideas on mounting new ESC - upgrading the week old Slash
    Yo! I just got my new 4068 2650kv motor and 150a ESC. Got the motor mounted with a new STRC motor mount. Relocated the receiver box but now I need advice on how to mount the ESC. This thing is huge compared to the stock VXL3S. I was thinking of just mounting it with double sided servo tape but not really sure how that will work since the bottom of the chassis isnt flat due to the honeycomb pattern. Thanks in advance!
    Oh...one last thing. Actually several last things....how do you make sure you have the proper gear mesh (not too tight vs too loose). And why is it recommended to swap out the slipper when going with a bigger motor?
    Jan 2016
    213
    I'll be in the same boat as you. Hopefully it gets solved so I can benefit!!
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    Run it, destroy it, fix it
    Indianapolis
    14,321
    STRC makes a plate specifically for mounting esc's for the Traxxas Slash 4x4's. You could also cut and old DVD cover and make your own.
    RC Champion MikeMcE's Avatar
    Feb 2016
    Deep in the Everglades
    1,291
    As I don't see any ears on the ESC I will recommend making or finding a flat plate, traxxas has some with holes drilled, I don't have a number, found it at the lhs. I drilled to fit and use 3M dual lock, like plastic Velcro, quite strong, they " snap" together
    HANG UP AND DRIVE!
    Slash 2wd 4x4
    PRO MT Yeti 4x4
    RC Qualifier gordon2456's Avatar
    Aug 2004
    Yankton, SD (south of ND)
    312
    I've used just a flat plate of carbon fiber. Tape your esc to the plate, bolt the plate to the chassis. Works great and is easily removable.
    REVO Platinum, Slash Platinum, TRX-1
    RC Champion Dcuda69's Avatar
    Jan 2015
    WI
    2,986
    Are there holes in the back of the esc for screws? My Hobbywing came with a plate. Two screws hold the esc to the plate then the plate screws to existing holes in the chassis. Maybe you could fab something like that?
    Slash 4x4 Ult 2150kv
    Rustler vxl
    Ford GT vxl
    RC Racer Skyline's Avatar
    May 2016
    181
    I know this inst relevant to the solution, but does mounting the receiver box up front give up any durability for the box?
    its not fun until something breaks
    Feb 2016
    342
    I have the hcg but the concept is the same. I made the first mounting plate out of some scrap plastic-
    Then I broke my chassis in half so I decided to make an aluminum one-
    And I feel the rx box up front makes it more vulnerable. I'm not moving it though.
    Sent from my SCH-I545 using Tapatalk
    Jun 2014
    Southern California
    7,680
    Just fab up your own mounting brackets:
    https://traxxas.com/forums/showthrea...=1#post6057936
    RC Qualifier Silly Old Boy's Avatar
    Jan 2014
    NE PA
    919
    You can do the same thing squeegie did with lexan too. Just get a sheet, cut it to length, hit it with a heat gun, and bend it. It's best to use a vice so you get a straight bend.
    Feb 2016
    1,291
    Traxxas 3725..... good starting place
    HANG UP AND DRIVE!
    Slash 2wd 4x4
    PRO MT Yeti 4x4
    Jun 2014
    Southern California
    7,680
    Feb 2016
    1,291
    http://www.teamstrc.com/index.php?ro...product_id=874
    best looking one around!!!
    HANG UP AND DRIVE!
    Slash 2wd 4x4
    PRO MT Yeti 4x4
    May 2016
    76
    Awesome ideas! Thanks guys!
