Results 1 to 14 of 14
    Feb 2016
    127
    Broken Chassis...
    Crashed dead on into a parked car's tire going about 50 mph...broke my chassis and warped my driveline Has anyone else ever broken a chassis? I'm not looking forward into transferring all the parts to a new chassis.
    Before the crash. Brand new body
    Slash 4x4 Ultimate
    Sep 2015
    2,242
    No. But I've never driven into a parked car at 50mph either.
    youtube.com/c/RazorRCvideos
    Feb 2002
    9,394
    I broke a chassis, well it was a bulkhead and 1 screw off the chassis for the swaybar... so the chassis had to be replaced also..... still didn't take long
    Jun 2014
    Southern California
    7,588
    Tedious, but not very difficult...
    All part of the fun of this hobby!
    Indianapolis
    14,241
    It is not a hard thing to do. I have broken more chassis than I care to remember! Is your truck and Ultimate Edition? If so just be careful of the wires.
    Canton Georgia
    2,149
    Its not hard to transfer everything over, just time consuming. I haven't broken mine but then again its been sitting on a shelf for 2 years
    Slash 4x4 LCG+(rolling)HCG, Slash 2wd(raptor)
    N. Idaho... Da Sticks!
    7,690
    I just went through this myself, its a little annoying, but not terrible. It is a good time to take a look at all of the parts you don't normally see, inspect them, and see if they need replacing. If you bent your center shaft, recommend taking a hard look at your diff inputs for cracks. When I had my crash I sheered the front one clean off, the back one had a hairline crack that likely would have failed in the near future.
    Feb 2016
    342
    If you did bend your center shaft, I would upgrade to the tekno big bone.
    As for the chassis, it happens. Now you have a reason to rit-dye the new one! It's pretty easy to change but I highly recommend a good set of tools before you start. I use the mip speed tip set #9512 and a cordless drill.
    Sent from my SCH-I545 using Tapatalk
    RC Qualifier whitie_bear's Avatar
    May 2014
    AB, Canada
    354
    Get a hot racing inner roll cage or vg racing brace...toughens up the lcg chassis
    RC Champion traxxasfan21's Avatar
    Nov 2015
    in sunny CA
    1,113
    Quote Originally Posted by whitie_bear View Post
    In a event of a high speed crash this can be bad because it spreads the damage elsewhere instead of letting it flex with the impact.
    Too much power is just enough
    Feb 2016
    127
    I found a seller on eBay that sells 4x4 LCGs for 20 dollars. I thought it'd be about 50. Looks like I'll start the project soon!
    Thanks for the tips!
    Slash 4x4 Ultimate
    Michigan
    8,203
    With the modular designee of the rig the job will be easier then you think.
    Also as mentioned above its a good time to check out a lot of other things that may have needed attention before or after the incident.
    Jan 2015
    49
    If I were you I would say it's upgrade time to go with I think it's Strc has an aluminum chassis I would be going with that
    Sent from my iPod touch using Tapatalk
    May 2014
    AB, Canada
    354
    i hit my trucks diff cover travelling top speed with 3s , disintigrated my roll cage but not one thing was messed up on the car...the aluminum gives, now if it was a steel roll cage i agree that might be too unforgiving, but in my big accents my aluminum cage has always given before anything else...then im left bending it back in the vice (after the diff issue there was no bending it back to normal hahahahah)
