Results 1 to 13 of 13
    Jun 2016
    JERSEY SHORE
    12
    M41 leaking motor cooler
    Has anyone had this problem im gonna try greasing it with shaft lube.
    Sep 2014
    154
    Replace that with a aftermarket aluminum unit.
    Jan 2014
    Ohio
    809
    This is a common problem and most put a metal cooler on. mine has the rubber cooler. I put silicone grease on when i installed it and so far no leaks. Don
    Jun 2014
    Merton, Wisconsin
    119
    Lol really traxxas, they couldn't even put a decent cooling jacket on the motor? $475 boat with a $5 cooling jacket that leaks instantly, pretty disappointing.
    Jun 2016
    21
    Quote Originally Posted by mxkid261 View Post
    Relax...not everyone is having issues with it. The same thing happened with the Spartan on it's first run. Buy an aftermarket one if you need to.
    Jun 2016
    JERSEY SHORE
    12
    besides the leak it runs good next run im gonna try the grim racer 42x55 prop. with the 8400 mah batts it blows the blades off the plastic ones
    Please watch the language.
    ksb51rl
    Jun 2014
    Merton, Wisconsin
    119
    Quote Originally Posted by Lostmontanan View Post
    Oh I'm relaxed don't you worry It could've came with a little nicer water jacket for the price tag just my .02 cents. You'd think they would've learned from the spartan.
    20,500
    Thanks for your suggestion. You are starting to repeat yourself.
    Alt-248 on the number pad =
    Jun 2014
    Merton, Wisconsin
    119
    I believe Im allowed to, correct?
    Eastern Shore, Maryland
    3,867
    I'm thinking we're going to have to do some of the same mods we did to our Spartans to get them all spiffy. If so, a few bucks here and there won't be to bad. You figure...a dual port rudder, aluminum cooling jacket, metal prop and your in business.
    20,500
    Suggestions:
    Look at your posts about this boat and the Spartan.
    Check the tone and the message.
    Take a hint and a breath and give it a rest.
    Oct 2015
    Missouri
    176
    I see both points here. It's true Traxxas could have addressed the cooling issue with the boat after the Spartan proved it was inadequate. I truly expected this boat to be fixed. If if the M41 had factory cooling upgrades I would have no problem paying 5 to 6 hundred for in the box. On the other hand, I can't wait to play with mods on this boat! A lot of potential to play with and I can't wait till I can buy one and start tweaking it! I'm just happy Traxxas finally put out a new boat! Thank you Traxxas and don't wait so long to put out another one.
    Mar 2016
    Colorado
    242
    Mine will be here next week, am I going to have to repair it when I first get it, do they all leak. Is it a simple fix?
