Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 171
Thread: New pede vxl..
  1. #121
    Apr 2016
    207
    Quote Originally Posted by Briber View Post
    How much play if any is in stub axle? Do they go in between bearings on stub axle?
    Sent from Eastern Missouri
  2. #122
    Dec 2015
    St. Peters, MO
    3,329
    Quote Originally Posted by dashfordx View Post
    Just hold on to them you may find later you need them to shim something up.
  3. #123
    Apr 2016
    207
    Alright thanks for your help
  4. #124
    Apr 2016
    207
    New pede vxl..
    Top pic is showing how far the stub axle goes inside the rim from the inside and bottom pic is showing how far the threads stick out from the rim from the outside. Is there something wrong? Do I need another part or something? Probably just missing something so simple
  5. #125
    RC Turnbuckle Jr. GeneralPede01's Avatar
    Sep 2015
    Toomsuba, Ms
    3,186
    Those are teknos which means it has a 6mm stub axle compared to stock 5mm stub axle. You will have to drill you hole bigger on your rims.
    Triple digit club member!
    100mph pede 4x4
    104mph Mamba Rustler
  6. #126
    Apr 2016
    207
    Quote Originally Posted by GeneralPede01 View Post
    100mph pede 4x4
    Alright. I'm gonna take another look at everything Bc I put some other wheels on there yesterday when I buttoned everything up after putting the new driveshafts on. The wheels in the post above are the stock talons. But thank you G-Pede
  7. #127
    Sep 2015
    Toomsuba, Ms
    3,186
    No problem
    100mph pede 4x4
  8. #128
    Apr 2016
    207
    New pede vxl..
    No problem
    100mph pede 4x4
    After further review, I've come to the conclusion that the Tekno hex (left) has a bigger hole for the stub axle than the stock pede hex (right)....neat
    My problem is that all of my stock talons and hexes have been stripped so I super glued the hexes into the rim. So now I'll have to pop those out and order another set of Tekno hexes to use my talons.
  9. #129
    Sep 2015
    Toomsuba, Ms
    3,186
    New pede vxl..
    That's because tekno has a 6mm stub axle and stock is 5mm
    100mph pede 4x4
  10. #130
    Apr 2016
    207
    100mph pede 4x4
    Yessir
  11. #131
    Dec 2015
    St. Peters, MO
    3,329
    Upgrade to 17mm wheels and get 17mm adapters and you won't have problems stripping out wheels and have to glue hex in them....
  12. #132
    Apr 2016
    207
    Got these aluminum shock caps in the mail today. Anyone know what the stock shock oil weight is?
  13. #133
    RC Qualifier czlynx's Avatar
    Jan 2016
    459
    I think it's 30.
  14. #134
    Apr 2016
    207
    Quote Originally Posted by czlynx View Post
    I think it's 30.
    Alright wanted to make sure I had the right stuff before I changed it. Thanks m8
  15. #135
    Apr 2016
    207
    I just ordered these proline mashers and they have a 12mm hex. Are they supposed to or not? I'm not sure. I also recently ordered 17mm hex adapters from Tekno. Will they be compatible with these?
  16. #136
    Sep 2015
    Toomsuba, Ms
    3,186
    Yes their suppose to have 12mm and no they will not work with 17mm adapters.
    100mph pede 4x4
  17. #137
    Apr 2016
    207
    100mph pede 4x4
    Dang. Do I need to order another set of adapters?
  18. #138
    Sep 2015
    Toomsuba, Ms
    3,186
    Their 12mm wheels should bolt up to your regular hexes on the teknos
    100mph pede 4x4
  19. #139
    Apr 2016
    207
    New pede vxl..
    100mph pede 4x4
    I am missing something. The whole point of me ordering these proline wheels was to upgrade to a 17mm hex. I'm pretty confused.
    I don't wanna strip these new wheels like I did the stock ones.
  20. #140
    Sep 2015
    Toomsuba, Ms
    3,186
    These are the wheels you need.http://m.ebay.com/itm/Pro-Line-2755-...150?nav=SEARCH
    They don't come premounted you have to mount your own.
    100mph pede 4x4
  21. #141
    Apr 2016
    207
    100mph pede 4x4
    Oh my...superglue will have to fix em of they strip.
  22. #142
    Sep 2015
    Toomsuba, Ms
    3,186
    Just keep a check on the tightness of your wheels very often and they should last you. There's a couple of ppl on here who run big power systems and still use 12mm wheels.
    100mph pede 4x4
  23. #143
    Apr 2016
    207
    Should they be tight tight or...?? I'm sorry for these insanely dumb questions. And I really appreciate you helping ne
  24. #144
    Sep 2015
    Toomsuba, Ms
    3,186
    As tight as possible, but be careful if you go all Hercules on them you could strip the nut or stub axle.
    100mph pede 4x4
  25. #145
    Apr 2016
    207
    Okay lol I'm no Hercules that's for sure. Thanks G-Pede, really appreciate it.
  26. #146
    Sep 2015
    Toomsuba, Ms
    3,186
    No problem and hope they last awhile for you.
    100mph pede 4x4
  27. #147
    Apr 2016
    207
    Yeah me too. Aren't too cheap...
  28. #148
    Sep 2015
    Toomsuba, Ms
    3,186
    No their not lol. I always mount my own now except the buggy wheels that I run.
    100mph pede 4x4
  29. #149
    Apr 2016
    207
    100mph pede 4x4
    I figured you did. I don't really know how to do that and I haven't really looked into it so it's easier for me to just buy premounted
  30. #150
    Sep 2015
    Toomsuba, Ms
    3,186
    It's pretty easy, I was the same way when I first got into this hobby. After glueing a couple sets yourself you'll tell yourself Wow that wasn't that bad. Plus when you glue your own sets you can tape them.
    100mph pede 4x4
  31. #151
    Apr 2016
    207
    100mph pede 4x4
    Yeah I heard about people taping them.
    I just looked on teknos sight and they have these aluminum 12mm hexes. You think would be good or would they just probably strip the hex easier?
  32. #152
    Sep 2015
    Toomsuba, Ms
    3,186
    I've heard the tekno plastic hexes are crappy, so I would get the aluminum ones.
    100mph pede 4x4
  33. #153
    Apr 2016
    207
    New pede vxl..
    Alright I'll probably get both and try.
  34. #154
    Apr 2016
    207
    Man, this thing looks amazing with these.
    I've already come across or problem. The side of the tire rubs against the shock guard when turning. You guys just take the guards off or has someone modded the guards to fit without rubbing?
  35. #155
    Sep 2015
    Toomsuba, Ms
    3,186
    They shouldn't be rubbing at all, which ones did you get?
    100mph pede 4x4
  36. #156
    Apr 2016
    207
    100mph pede 4x4
    The 2.8s for front and rear
  37. #157
    Sep 2015
    Toomsuba, Ms
    3,186
    This is the ones you need.
    If their rubbing then you probably have these and their the wrong offset.
    100mph pede 4x4
  38. #158
    Apr 2016
    207
    Ahh okay yeah that's it
  39. #159
    Apr 2016
    207
    100mph pede 4x4
  40. #160
    Sep 2015
    Toomsuba, Ms
    3,186
    I made the same mistake before, I had to dremel the shocks guards down, or you could just take them off in the front.
    100mph pede 4x4
