Results 1 to 10 of 10
    Mar 2016
    124
    Stampede transmission cover with 90t ?
    Very new to the stampede I just picked up a used one in very nice shape has a new Titan 12t in it my question is it did not come with a transmission cover when I went to order one rpm states not recommended to use with larger then the stock 84 tooth the spur in this truck is 90t I would like to put a cover on it since it will see bashing in the dirt can I still get a cover for it ?
    Feb 2002
    9,401
    try a stock one.... where are you located, I have like 5 of them that I don't use....
    Mar 2016
    124
    I am in nj
    Jul 2012
    Finland
    31
    You can run with out gear cover.
    Slash 2wd,stampede 2wd,latrax sst
    20,529
    Quote Originally Posted by Antnand78 View Post
    I am in nj
    Tell me where you want to meet and you can try either. I'm sure I at least have an extra, unneeded stock cover.
    Alt-248 on the number pad =
    Mar 2016
    124
    I would like to put a cover on it so when I run it on dirt it doesn't get all caked in there here is the truck
    Sep 2011
    North Jersey
    90
    Pm me I forgot to give you the cover that day.
    Drive it like you stole it
    Dec 2008
    Norway
    90
    The rpm cover is the way to go. My spur gear got damaged with the stock cover from small rocks and dirt that came through the opening.
    Get a the rpm cover, 86t spur gear and a 16t pinion gear. That is a very good allround gearing for the titan 12t
    Mar 2016
    124
    The rpm cover says it won't work with the 90t set up which I want to stay with any one try one with the 90t
    Dec 2008
    Norway
    90
    87 is the largest you can go with the rpm cover.
