Results 1 to 13 of 13
    Mar 2016
    124
    Breaking in new 2.5 engine glow plug question ?
    I am following the traxxas manual for the break in of a new 2.5engine with new carberator also installed new header pipe with factory resonator because the truck had upgraded exhaust so the first tank went no problem on the second tank the first plug burnt up so I didn't have any spares on me so after a couple days I started the second tank over again the 2 nd plug lasted the 2 nd tank then blew on my third plug which has lasted the 3 rd and 4 th tank my question is how many plugs is normal during the break on ?
    13,698
    One .
    Mar 2016
    124
    Even traxxas says you will go through plugs during break in just wanted to know by expierence on here how many people have used
    Mar 2016
    124
    Has anyone gone through this ?
    RC Racer Nitrocrazy66's Avatar
    Jan 2016
    Colorado
    186
    Nope only used 1 here
    "Drive it like you stole it"
    Apr 2016
    40
    I used one glow plug for my whole 1st gallon of fuel. The 2nd gallon of fuel i went thru 4 glow plugs.
    Oct 2015
    Maine, US
    51
    You're probably running too rich if you're going through that many glow plugs. Yes, it is normal to go through one or two plugs during like a 10 tank break in. Check if your needles are set to factory.. But even factory is rich.. What brand and type of plugs are you using? OS plugs have lasted the longest for me.
    P2de VXL
    T-Maxx Classic
    Rusty SW3
    Mar 2016
    124
    I am using traxxas 3232x plugs . Should I set the hsn to 4 turns out or 4 1/2 ? Also the temp outside has been in the high 80-95 range with high humidity could this be affecting things ?
    Oct 2015
    Maine, US
    51
    For break in, the HSN is supposed to be 4 turns out. For the plug, I would try an OS LC3 plug. From what I understand, when it is hot out, you should run leaner.. but you also need to run richer to help the engine cool . So id say just stick with the factory carb settings for the break in procedure. Also, make sure the LSN is flush!
    P2de VXL
    T-Maxx Classic
    Rusty SW3
    May 2016
    USA
    12
    Is your engine overheating too? Watch the temps, if it overheats your almost 100% guaranteed to lose a glow plug.
    Mar 2016
    124
    What's an overheating temp for these engines the highest it's been is 250
    May 2016
    USA
    12
    That's low. If you get into the 300's its too hot.
    Traxxas T-Maxx 3.3
    Traxxas Slash 2wd
    Mar 2016
    124
    Ok good I was hoping it was getting to hot gonna wait till it cools off a bit I have to swap out the brake In it then I will wait for cooler weather I was running it when it was in the 9os out and very high humidity
