Results 1 to 2 of 2
    Jul 2016
    Pulling the slayer & slash outta the closet
    Slayer: Servos doing nothing at all when turned on.
    New batteries.
    Have 6.5V going to the 2216 receiver. Have voltage coming out of receiver on all channels.
    Have a known good transmitter, and new crystals installed
    Have tested fault with another 2216 receiver, and nothing.
    Any good ideas?? Vehicle worked fine when boxed up a while back.
    Slash: mamba setup, everything comes on and works as it should. Except that in either forward or reverse it just lunges and then stops. Do I just need to plug it into the laptop and tune it? Never have done that.
    13,667
    If you have a good transmitter and receiver and the servos do not work then swap out known good servos and see if there is still a problem.
