    Jun 2016
    7
    Problems with acceleration
    I recently just rebuilt both differentials and took it out to drive. It was running good, but then I started increasing speed and on the road when taking off it would pull really hard to the right. I've tried adjusting steering trim but that doesn't work. Anyone know any solutions? Oh and I'm running 6s
    Mar 2016
    43
    might want to tear apart the differentials again.
    Jun 2016
    24
    On my erbe it doesn't matter what I do, short of really babying the throttle, it pulls when accelerating running on 6s
    May 2016
    274
    You need to run heavier diff fluid for sure. I was using 60k but I feel 100k would be better. Also I would shim your front a arms upper and lower with washers to take out the slop. My ERBE had slop in the arms with my Rpms so I put washers Inbetween the arms and bulk heads on the suspension pin. Worked wonders! I circled the area im referring too. Too and bottom you need to do.
    V1 BL5/2028, V2 max6/5882, Erevo, Summit, Rustler.
