Thread: X maxx slipper
    Feb 2016
    301
    X maxx slipper
    Does any one know if the x maxx slipper will fit if so do u think it's worth it
    Eastern Shore, Maryland
    4,168
    If you have a Xmaxx give it a shot. If not, see if one of your friends has one, and if they will let you try one during the up coming off season.
    Feb 2016
    301
    I have a x maxx but will it be worth it
    4,168
    Who knows. That's why you would have to try it to find out. For me, I have both too, but I'm not having any problems with my XO's slipper. For me...me being a ReglarGuy...I go with if it ain't broke don't fix it mentality.
    Oct 2014
    United Kingdom
    59
    I'm honestly not sure it'll fit or how it'll fit looking at the photo -
    The XO-1 uses the crush-drive system, which in comparison is quite compact and uses a splined pinion to transmit the power along the prop shaft to the front diff, so it's a very different kind of system, plus space will also be limited in the chassis, so i'm not sure it will be an easy fit.
    Generally on a road car you don't really want a slipper clutch either, you want all the power transmitted to the wheels. The crush-drive system merely softens the impact on the drive-train but transmits as much of the power as possible to the wheels.
    On loose surfaces, the slipper clutch absorbs shock loads on the driveline and gives an off-road car the strength to blast full throttle across rough and rugged terrain. So if say a wheel/diff gets stuck, the slipper clutch will save the expensive electronics and stop them burning out. Generally on road, wheels/diffs don't get stuck, so no need for a slipper clutch on road, thus most on road cars are either direct drive, or like the XO-1, have a bumper system in the drive-line to ease loading and reduce long-term stress.
    Feb 2016
    301
    Thanks for the pics
    RC Qualifier RadReptiles831's Avatar
    Nor Cal
    869
    If your looking to add a slipper clutch check out Er33's thread. He did it by modifying a slash 4x4 clutch. It's works great. He actually made one for me so I have first hand knowledge on it. The great thing about is I now can run any mod 1 gears now. Check out his build thread. https://traxxas.com/forums/showthrea...-Gt8-XO1-build
