    May 2006
    FL
    759
    Best Tires For Limerock Roads?
    I recently moved to an area with all limerock roads, after being on concrete and grass for over 20yrs with RC's this is something I can't seem to get use to. I can't do anything with my E-Maxx. The limerock dust seems to make my truck just spin and want to do donuts even with the slightest power. I have tried the stock E-Maxx BL tires, SportTraxx and Respose tires with no luck at all. Any suggestions?
    Apr 2016
    24
    The 40 series tires Proline makes - Mashers, Trenchers, Big Joes - are a bit wider and have a more aggressive tread pattern which would help with traction.
    If all else fails you could put a center differential in your truck which would put more power to the front wheels and make the truck easier to handle on loose surfaces.
    Jan 2015
    Nova Scotia, Canada
    142
    T.S.M. problem solved. maybe loosen your slipper a quarter turn, and you could even pull out a little of the spring clips on the shocks. this advice should help drastically. happy bashing.
