Results 1 to 16 of 16
    May 2016
    37
    Proline Prime 2.8
    Hi,
    I'm looking at Proline Prime 2.8. I was wondering if I need to gear down or are they the same size as stock tires. If I need to gear down what gearing should I use. Also I was planning to glue them myself, any advice on glueing?
    Btw my car is a Rustler VXL with a Hot racing transmission. I run Floureon 5200 mah 30c 7.4v 2s Lipos. I drive mostly street.
    May 2016
    37
    Will these 2.2 tires fit without having to change gearing?
    https://www.prolineracing.com/tires/...d-truck-tires/
    May 2016
    37
    Are the 2.2 tires I found Traxxas style bead?
    May 2016
    37
    Do 2.8 wheels fit 2.2 tires?
    RC Qualifier WonderMelon's Avatar
    Mar 2016
    Myerstown, Pennsylvania
    957
    These are the ones you'd want
    Rear
    http://www3.towerhobbies.com/cgi-bin...?&I=LXFLXM&P=M
    Front
    http://www3.towerhobbies.com/cgi-bin...&I=LXFLXL&P=ML
    BUT I would highly suggest getting the RPM wide front arms.
    http://www3.towerhobbies.com/cgi-bin...?&I=LXFEVM&P=7
    Links you need
    Camber
    http://www3.towerhobbies.com/cgi-bin...Fc1bhgodQosGLA
    Toe
    http://www3.towerhobbies.com/cgi-bin...FRRbhgod0U8Iww
    You'll just two two pairs of REAR offsets with the wide arms
    May 2016
    37
    OK thanks. What do you mean by two two pairs of rear offsets?
    May 2016
    37
    Also do I need to gear down to use those tires?
    Sep 2014
    82
    Wheel offset is the distance between the center of the wheel surface where it mounts to the hub compared to the actual center of the wheel. The further the center of the wheel is to the outside of the wheel, the closer the wheel is to the car. So all in all the wheels in the front compared to the back may be different. If you were to put front wheels on the back they may stick out further. 2.2 tires/wheels are different size than 2.8. 2.8 is bigger. If you buy 2.2 they need to be on wheels meant for 2.2.
    May 2016
    37
    Ok thanks for making it clearer for me!
    May 2016
    37
    The 2.8s are bigger than stock right?
    May 2016
    37
    Will I need to change gearing to prevent the 2.8 Primes from overheating my motor?
    May 2016
    37
    The Anacondas I have are about 3.9in and the Primes are 4.4in. I was thinking of the gearing being 23/90 for the Primes. Will that work?
    Mar 2016
    957
    They're the exact same size... And if you thought about 'wide' arms... It means if you use rear offset in the front AND back you'll get better steering and you can swap out tires.
    May 2016
    37
    Ok thanks! I'm getting the RPM a arms.
    Sep 2014
    82
    no I believe Rustler stock tires are 2.8
    Apr 2016
    36
    Rustler stock wheel size is 2.8
    Tire diameters and widths will vary.
    I have a set of talons on 2.8 wheels that are huge compared to my anacondas, also on 2.8 wheels.
    Sent from my XT1575 using Tapatalk
