Results 1 to 12 of 12
    Detroit, Mi
    508
    High speed gearing
    I am looking to what mod 1 gears will fit into the LCG chassis, I am running a 2200kv motor. I have tried a 23p and a 40 spur and that did NOT fit. I have seen possibly a 34s with a 22p will fit, but I have not seen much more.
    I have been using the standard 32 pitch gearing with a 22p and a 50s but I max out at 80mph, I would like to get a lil more. I know the 2650 would be a lil better with more RPM available with 6s compared to the 2200kv.
    If need be I do have the 1/10 scale 1415 2400 kv castle motor as well.
    Any help or suggestions would be appreciated.
    ERBE, EMBE, big block MERV, Sl4sh
    Feb 2002
    9,417
    check out the setup of phildog
    Jan 2003
    nc
    2,556
    Nay need to grind some on the plastic mount to make room for the pinion gear. or run a smaller spur gear.
    slash 4x4 168mph
    youtube:philip jolley
    Apr 2001
    Queens, NY/Orlando, FL
    520
    I'm running a 26P/50S on my standard Slash chassis (not sure how the LCG differs)
    https://www.youtube.com/watch?v=Qo4DOVsGKAU
    https://www.youtube.com/watch?v=Zy4H_neJrts
    Feb 2010
    Indianapolis
    14,617
    Quote Originally Posted by 98 SNAKE EATER View Post
    The LCG chassis is way more stable! It handles leaps and bounds better than the HCG chassis. You can really see the difference in cornering performance at speed. You can brake later and accelerate faster in and out of the corners.
    Apr 2001
    520
    I meant in the way the gears are mounted.
    Any issues running a large pinion or a large spur? (I remember having to grind a bit off to fit a 56T spur)
    RC Qualifier Beefred00013's Avatar
    Jun 2016
    263
    Have you tried running it with a spur on spur gear
    Dec 2007
    Manassas, Va
    7,181
    if you're out to really gear the crap out of it, you can always use one of Saga's mounts. I've got a couple and they're awesome.
    http://www.sagacustomrc.com/store/c3/Motor_mounts.html
    One mans garbage is another mans ungarbage" -Ricky
    RC Turnbuckle Jr. Jimdog's Avatar
    Iowa City, Iowa, USA
    4,361
    I can fit 23/36 in my rally.
    This will TOTALLY work, saw a guy on YouTube do it
    Jan 2014
    377
    you prolly need to use mod 1 gears and not 32p especially for the 2200kv on 6s.
    use revo 3.3 36t spur mod 1 and start out with 24-26t pinion mod 1.
    I run that on my rustler with 2200kv on 6s and 39ts and 28t pinion mod 1 on my losi running 2200kv on 6s as well
    Jun 2016
    263
    And if I can use two use two Spurs what would you suggest
    Jan 2014
    377
    Quote Originally Posted by Beefred00013 View Post
    you will need a spur adaptor to run a spur as a pinion.. search rawsteele, rc hornet, or sagacustom rc
