Page 1 of 4 123 ... LastLast
Results 1 to 40 of 125
    196
    My X-Maxx Project
    Bought a used X-Maxx with Leopard 5892-1340kv engine and a Hbbywing max 5 esc. Fit a T-Bone front bumper. Run on 29/54 gering and 2x3 cell 5000mAh lipo. Think that it goes well with this, the engine was a little warm but drive hard hard. Got to be a fan when I returned home, think that the steering gear is sloppy. Can you tighten the servosaver or is there something else to do. Run with Traxxas standard servo. Some pictures of this.
    Aug 2016
    173
    Awesome. I'm considering that bumper. Can you pull the stock bumper off?
    Sent from my HTC6535LVW using Tapatalk
    196
    Quote Originally Posted by jeffm1000 View Post
    Original bumper stays behind the T-Bone.
    Mar 2016
    1,155
    You might wanna get a bigger fan,also yes I believe there's a adjustment for servo saver,,and I would recommend getting a better batteries,,I have the same setup but geared 35/46,all steel gears even output gear,I'm using 3s 8400mah & SMC 4s 5200mah.
    "AVENGED SEVENFOLD "
    196
    Quote Originally Posted by PATS4LIFE View Post
    Should have a 50x50 fan but had only 40x40 home today. Do you have any good site to buy 50x50 rc fan?
    Mar 2016
    1,155
    Quote Originally Posted by painter View Post
    they should have some on eBay,I'm using 60x60 fan,u can also get the dynamite 1/5scale dual fans from KD
    196
    Sitting and look at a new servo to the car, the two that I choose from.
    Savox SC-1268-SG https://www.amainhobbies.com/savox-s...1268sg/p183318
    Savox SB-2270 SG https://www.amainhobbies.com/savox-s...2270sg/p210495
    Have you tried any of these servo and does they fit in Traxxas Adapter.
    Mar 2016
    1,155
    the stock servo has a better torque than both of those @6v,definitely not the first one.
    If u can get either one of this it's much better and it will work with the adapter,but if you are to replace stock servo,you won't be able to use the stock servo horn also,you will need a different servo horn.i believe you will need the Futuba 25t servo horn.
    http://www.taildraggerrc.com/bluebir...digital-servo/
    196
    Ok, did not think the original servo was so strong.
    Mar 2016
    1,155
    stock servo is 365oz torque@6v
    Mar 2016
    1,155
    No I don't have the cover on ever since I switch motor,but you can modify it if u want it on,someone here posted it on how to. I'll try to find the thread and get back to u..here u go
    https://traxxas.com/forums/showthrea...pur+gear+cover
    196
    Ok, I order a Savx Monster Full Alloy Power SB-2290SG 50kg / 0,13s.
    Easy to buy in Sweden,
    I come bck with pic in some day.
    Mar 2016
    1,155
    is it this one?
    http://www.hobbypeople.net/index.php...94-4at7-4.html
    Don't forget you need servo horn,you can't use stock one.
    Dec 2013
    42
    is it this one?
    Isn't there an adapter available that will allow use of the stock horn? i saw a link on here somewhere, I think it was to a-main. Or is that an adapter that is only for the bluebird servo?
    What is the spline count on the stock servo?
    Mar 2016
    1,155
    Quote Originally Posted by Tulo52 View Post
    havent seen or known anyone that have use an adapter to use the stock servo horn with aftermarket servo.
    And you will need this also,or something similar
    http://m.ebay.com/itm/GPM-TXM024A-OC...976?nav=SEARCH
    196
    is it this one?
    Yes it is. i order this. http://www.kullagergrossisten.se/pro...aba-savox-16mm
    196
    A little test run, a little bumpy.
    Run the original oil in the dampers, but will try with 50wt.
    What happened with the sound, I do know ...
    https://www.youtube.com/watch?v=pIMu...ature=youtu.be
    Mar 2016
    1,155
    nice video,sound is working fine,what gearing setup your using?
    196
    I drive 29/54.
    Apr 2016
    148
    Wow what did you use for body screw savers? Washers? Link?
    196
    Quote Originally Posted by Hallett240 View Post
    Run with ordinary washer that I bought a local hardware store, recessed them a little with a standard drill and painted them black, the screw was Countersunk hex screws ca3x18mm,
    Sorry for my spelling, google translat
    May 2014
    21
    hay
    painter
    i thinking buying the leopard too
    i changed the esc to hobbywing max 5 and stays with the original engine.
    does your leopard fit perfectly ? or you had to change / cut somthing ?
    i will very glad if u can post a pictureof the vehicle
    thank you
    Mar 2016
    1,155
    Quote Originally Posted by Ohadvip View Post
    hay
    painter
    thank you
    You don't have to cut anything for leopard motor,u just meet to get the motor mount from KD.
    196
    Hello, you need to remove a crossbar in 7714 otherwise it is just to purchase KD motor mount. Have no great photos of it there is a fan right over now.
    Have only one showing the crossbar as I took it away.
    Good luck
    Mar 2016
    1,155
    Oops yes forgot about that,yes definitely cutoff the crossbar,thanks painter!!!
    Mar 2016
    1,155
    Here's a video of it..
    196
    Do you have any link where you purchased the fan?
    Mar 2016
    1,155
    http://m.ebay.com/itm/2-Pieces-GDT-5...120?nav=SEARCH
    196
    Thanks very much.
    196
    Got servo Today, fit into the adapter.
    We'll see if I have time to test mount something tomorrow.
    Mar 2016
    1,155
    That's a nice servo you got hopefully it's worth it,post feedback about it when u get a chance to test it..
    196
    Ok, now I got there the servo in. Some dremling on the chassis do I have to do.
    Showing some pictures so you can see how it went.
    Going to buy a different servo horns so it becomes a straight line to the servo arm.
    Mar 2016
    1,155
    Wow clean install,but yes definitely need a different servo horn..
    196
    Had time to run a little before the change of servo today, nothing broke.
    https://www.youtube.com/watch?v=k6Ts3TmKPzA
    196
    Some movie on this first clip original servo, then Savx and the last of the taking of the body quickly
    https://www.youtube.com/watch?v=ROVyMXCHk7o
    Mar 2016
    1,155
    Nice videos,I wish I had a place like that here to bash...
    196
    Now I have ordered 2x4 cell lipo batteries to see how it goes.
    Is very satisfied with the car that holds together well. Wondering how you set the slip clutch? I have applied it fully. Perhaps i should loosen it a little bit?
    Mar 2016
    1,155
    I have the spur adapter so mine is fully lock at all times,,
    But tighten yours fully then 1/8 back.
    196
    Now I change the servo horn to Hudy.
    Put the screw in the 20mm hole instead of 16mm which was the only possible with Integy.
    Now it is much better line.
    Mar 2016
    1,155
    so how is the servo working for you?did u have to use BEC to run 7.4v?
