Thread: strange noise
    Jun 2016
    13
    strange noise
    My rustler has started to make this really high pitched noise and the car moves very slow. My spur gear is fine and so is the slipper clutch. I went into the transmission and diff but founf nothing broken. What can I do to fix it.
    Jul 2014
    NAWLINS
    3,952
    sounds like you need to tighten the slipper nut. I run all mine snug w/1/8 turn out.
    T/SportMax/Slayer Pro/Bandit
    Stampede/Rustler
    Jun 2016
    13
    ive been running it only 1/4 turns out so its not loose at all, it still does the thing
    N. Idaho... Da Sticks!
    7,694
    Most likely the pin for the top gear or a stripped idler gear.
    Jun 2016
    13
    my idler gear is fine and so are the other parts of my transmission including the inside of the diff, none are stripped or cracked.
    Aug 2015
    Australia mate...
    159
    Have you checked you haven't stripped a hex?
    Aug 2016
    South Carolina
    72
    You might also want to check what condition the slipper plate is in, it might be too shiny or the slipper clutch pads might glazed.
    Nitro junkie, but I dabble with electrics.
    Jul 2014
    710
    last time that happened to me ,,,, my wheel nut was loose and the hex pin fell out...
