Results 1 to 12 of 12
    Jul 2015
    MN
    150
    New Stuff, Need advice!
    So I ordered 7 things this weekend: big bores, 3s lipo, bearings, battery cover, 50 w oil for shocks, 76T spur, and aluminum bell crank steering. Here are my simple questions for you, how do I fill up my shocks with oil and what is the little C rating on lipos, like it says 25C discharge. Also is it fine if I can do speed runs with 2.8's? I have pro-line mashers for my tires. I'm running a sidewinder sv3 and a sidewinder 4600 kv motor.
    Big tires do wheelies!!!
    N. Idaho... Da Sticks!
    7,572
    C rating is the burst discharge rate, (C-Rating) x (capacity) = burst.
    5000mha (5amps) x 25 = 125 amps
    With 3S, you normally gear down, not up. Before you do anything, recommend getting a temp gun. When you change anything in the drive train (gears, tires, shafts, voltage, rebuilds and repairs) it is a REALLY good idea to take temps every five minutes or so for the first pack, anything > 260*/f is bad.
    For shocks, look on YouTube for "rebuilding Traxxas shocks".
    RC Qualifier MECHANIC77's Avatar
    Sep 2016
    Canada
    365
    I'm not sure, but you just need to check out in your ESC instruction manuel,if your ESC could run a 25c battery,and if they say no, running with it will probably toast the system and void the guarantee.
    Good driver. Bad setup. Bad things will happen...
    Jul 2014
    NAWLINS
    3,952
    This is a good vid on shock rebuilding......
    https://www.youtube.com/watch?v=HNJy7kreK90
    As far as the 25c, IDK what brand you have but I have 2 25c off brands that work fine in my SV3 4600 but a higher C rating would be better.
    T/SportMax/Slayer Pro/Bandit
    Stampede/Rustler
    7,572
    C-Ratings aren't normally a restriction for ESCs. The ESC is what pulls the power from the battery, the higher the C, the more the battery can supply (amperage). You can have a 70C pack, and the ESC might only pull 40C max. 25C is a low C rating (20 C is the lowest), for the most part, the higher C rating the better.
    You do want to make sure that ESC can handle 3S. (2S = 7.4vdc, 3 = 11.1vdc)
    Jul 2014
    NAWLINS
    3,952
    The SV3 can handle 3S but as always monitor your temps. My 4600 will get warmer with 3S than 2S but still way under the limit.
    I do run 2.2 Badlands on my Rustler so there not a heavy tire.....
    Stampede/Rustler
    Sep 2016
    Canada
    365
    Thanks for the info,because from now I did not know how things was working exactly.
    Maybe its possible to run a 25c battery, but that will certainly restrained the gearing option. or in other words the correct gearing range will be narrower.
    Jul 2014
    NAWLINS
    3,952
    [QUOTE=MECANIC77;6312448]
    Not so... I run every imaginable gear ratio with mine. The burst GS is referring to is the amperage the battery can give at a split second. As far as I know the burst is short not throughout the whole run.
    Stampede/Rustler
    Sep 2016
    Canada
    365
    [QUOTE=JerrysMaxx;6312463]
    Quote Originally Posted by MECANIC77 View Post
    Interesting... So if I understand your reflection with a higher c rating, if the ESC and motor permit, the aceleration could be better, or something?
    Jul 2014
    NAWLINS
    3,952
    This site and from other members is where I have learned a lot but to answer your question,yes but as noted the ESC and motor must be able to deliver.
    http://rogershobbycenter.com/lipoguide/
    Stampede/Rustler
    Sep 2016
    Canada
    365
    Thank you very much Sir!!!
    When i will read it I hope to don't forget to wink my eyes...
    Jul 2014
    NAWLINS
    3,952
    Your welcome! It sure gave me a better understanding when I switched from nitro. I'm no electrical wizard by far but I do manage.
    Stampede/Rustler
