A lot of reviews indicate the stock motors are problematic and fail early on in ownership.
Wondering if this is a wide spread issue, quality control and if the motors have been upgraded from factory as time has maybe improved the product, The Alias, as part of normal product improvements from Traxxas.
Or are pilots just upgrading to (and which if at all) other motors?
Thank you.
There was a later version motors that came out with no holes in the end cap. Many were quick to discredit the motors only to realize that most of the failures resulted in crashing under power or trying to power the Alias out of a barrier that prevented the blades from spinning. Myself included. Knowing this the motors last a lot longer. Life of the motors is around 4-5 hours or so which is the same as motors from Micro Motor Warehouse (which I owned as well but noted no difference in performance).
Agreed, my Alias motors last much longer now that I know what kills them off !
sent from Northern Vermont
Is the motor problem fixed
Is it hard to change out the motor
Sorry for all the questions but since traxxas says lifetime electronic warranty does it cost anything for new motors
Not hard to change.
Traxxas warranty is limited; read up on it. Their customer service is one of the best out there and have handled us on a case-by-case basis but when motors start to fail they cost around $30/set or so.
Ok thanks for the help
I get 20-25 hours flying time and I go pretty hard. 6 batteries I run non stop with 10 min cooling breaks in between.
It is pretty easy to swap the motors out. I've had my alias for years. Once you get good at flying and don't crash much I changed all 4 motors once one quits. Otherwise you willchange one, then a couple packs later the next one quits......
But if your damaging motors by not powering down BEFORE you crash then this would get expensive
happy flying
What do u mean by power down before crash
cut off the throttle. Ie lower the left hand stick immediately and ideally before you hit something as if the motors are under load and then you crash you are more likely to damage them.
It takes some practice but with my terrible flying I got pretty good at cutting the throttle quickly![]()
Thanks and do u have more tips u know for me
I don't
im not that great a pilot haha
I did find though I went full orange in the front, canopy, blades and light covers and blue in the back. Made it easier to see orientation
I haven't flew mine yet because I'm getting it for Christmas but hopefully I'm good
Should I buy the camera
Ok will it take me a while to be able to fly it or is it easy
Depends on you're expectations I guess
northern Vermont
How many battery should I buy and what kind of extra parts would u recommend
I'm a little overboard, I have 10 battery's, and everything else to build a Alias but a control board . I'd say 5 is a good amount. It does come with spare props .. the gear wheels that drive the props and a few motors are nice to have
northern Vermont
So your alias is all custom
Hmmm , mostly all La trax spare parts , I have a white frame and battery tray , black chrome frame , every canopy color they make , gears , bearings, prop shafts, bunch of props, the little rubber landing pads , I have tried the mmw dark motors and have tried a few different battery's looking for longer fly time .
Nice lot of money in all of that
The Alias parts are inexpensive , but it does add up !
I'm sure. I've been watching videos for tips but they done really tell nothing
Here's my finger spin ... https://www.youtube.com/watch?v=HguxIo9Y-g8
we have 3 alias in the house and since last sunday, i have orderd motors,props,gears,batterys,chargers, and even bought some dark series motors from another vender that to me didnt seem worth the money.
on all 3 drones we have had at least 1 motor just quit and all 3 have been on the red prop side, and all 3 have teeth missing on at least 1 gear and guess what there on the red prop sides lol. weird. other then that there pretty fun to fly and pretty durable.
If you're knocking teeth off the gears then your putting stress on the tiny motors by getting tangled up in stuff . Once you learn to cut power just before hitting obstacles the motors will last much longer . I know, I've been there. .. broken everything there is to break on the Alias many times over. Fly them all the time now with very little failure.
northern Vermont
I got one of these for Christmas. Halfway through my 2nd battery 1 motor stopped running. No hard crashes and now power on barrier strikes. Just stopped working. The blade spins freely with a finger flick. Smoked motor?
