Results 1 to 24 of 24
    Oct 2016
    43
    sand paws or sling shots
    I want new tires for the upcoming midwestern winter and want some Proline Sand Paws but I don't know if they will fit the rims I will buy to match the ones I already have on my truck (I don't know how to put pictures on here but they're Traxxas 5884's look it up ) and I know Proline makes the Slingshot which are meant for the short course truck but I think the Sand Paws look better please help!!!
    May 2013
    347
    I run the 2.8 Sand Paws in the winter, imo they are much better then the Slingshots, which I also have. My advice would be go with the 2.8 Paws, you will need to regear and will need the extended body mounts to avoid body rub but the performance is worth it!
    RC Champion traxxasfan21's Avatar
    Nov 2015
    in sunny CA
    1,113
    I use 2.2 sand paws for my merv and they work amazingly for beach running. Haven't tried it out in the desert though.
    Too much power is just enough
    Oct 2016
    43
    Quote Originally Posted by traxxasfan21 View Post
    do they fit on the rims i want?
    Oct 2016
    43
    Quote Originally Posted by chopperguy View Post
    how do i put pictures on here i cant figure out how to if i could, i could show you my rims
    May 2013
    347
    The wheels you mentioned are 2.2 / 3.0, the 2.2 Paws will not fit those as they are 2.2 on the inside and outside. I believe only the slingshots come in 2.0 / 3.0. The slingshots are ok, but are kinda skinny and tend to dig down to fast.
    Oct 2016
    43
    yeah i was afraid of that i wouldnt really want to go with the 2.8 paws because of the regear and the extended body mounts
    Oct 2016
    43
    Sent from my iPod touch using Tapatalk
    there is my rims im gonna buy
    Traxxas Slash Raptor
    Nov 2015
    in sunny CA
    1,113
    Quote Originally Posted by BOLTTHESUPERDOG View Post
    No because the 2.2s are for the rustler and bandit. I was saying how I like the sand paw design. 2.2/3.0 are a different size.
    Oct 2016
    43
    Oh ok. So I would probably have to go with the sling shots if I didn't want to modify the gearing or body posts?
    Nov 2015
    in sunny CA
    1,113
    Yes you would. Even then I would still gear down a tooth or two.
    Oct 2016
    43
    Ok I have the stock pinion and an 83 spur
    Oct 2016
    43
    And one more thing. What else could you use to glue the tire besides tire glue because it's so expensive , I read somewhere that you can use superglue / crazyglue
    May 2013
    347
    2.2 will fit a slash as the hexes are the same, you could run pre mounted 2.2 Paws it's just the wheels will be different. The other important question is are you running a brushed or brushless motor? Bigger tires on a brushed system with definitely shorten its life...
    Nov 2015
    in sunny CA
    1,113
    Most CA glues should work. I would gear it 21/86.
    Oct 2016
    43
    Ok I'll have to get a pinion
    Oct 2016
    43
    I'm running a brushed Titan 12t
    May 2013
    347
    Running the brushed motor I would chose the slingshots. I believe the stock gearing on the brushed slash is 19/90? In which case you would be fine. The optional 23/86 is the optional high speed gearing.
    May 2013
    347
    Found an old pic with the Slingshots on! Out on the lake on hard packed snow.
    N. Idaho... Da Sticks!
    7,600
    I have tired both, the Sand Paws work a lot better.
    The 2.8s will not fit under the stock body, so you will need to run higher body mounts, or modify the body a little bit. 2.2 wheels will work on a the back of a Slash, just not on the fronts.
    RC Champion traxxasbrothers's Avatar
    ON, Canada
    1,358
    I've had slingshots on all fours of my Slash 4x4 and sand paws (back tires) on a Slash 2wd, I can honestly say I was more impressed with the Slash 2wd and the sand paws in the winter.
    I broke it again . . . \_(ツ)_/
    Oct 2016
    43
    Ok I will think about that. The main thing is that I want something that I can just swap my normal wheels/tires with when it snows. Then use the normals for everything else. (Something to switch quick) so I'll probably go with the SS just because it's faster.
    7,600
    Just keep in mind, it isn't just works better, but what works at all. For SS to really grab it has to be hard-packed snow, anything fresh and they will not hook up, which is why I went to the 2.8 Sand Paws.
    Oct 2016
    43
    i really like the SP's but if the slings already fit the rims ill buy then i think ill go with those mostly what ill be doing is in the backyard bashing around
