    Nov 2016
    Question Traxxas EZ start with LiPo?
    Hi there,
    Im new to the community, and just had a quick question. With the Traxxas EZ start wand, is it possible to use a 5200mah LiPo battery? I also have a 1400mah Lipo, if 5200mah is too much power. If so, these both have a deans connector. In order to connect the battery to the EZ start, must I use a male deans to a female tamiya? If this is the case, does the EZ start require a large or small tamiya connector?
    Thanks,
    Jackson
    Sep 2011
    Iowa City, Iowa, USA
    4,355
    I don't know which connector it takes but it should take a lipo. As long as it is 2s. It won't have a low voltage warning though.
    Jul 2014
    NAWLINS
    3,952
    I use my 2S all the time. Mah is more on the time side than power. The higher mah will last longer but have no more power than say a low mah. Power is in the voltage and this is why I use 2S vs. 3S. Never tried 3S as it is not needed and a higher mah is not needed unless you have no wat to charge it for a few days.
    All that is needed is a Tamiya to Traxxas plug adapter. I use velcro to strap the battery to the wand.
    T/SportMax/Slayer Pro/Bandit
    Stampede/Rustler
