Results 1 to 11 of 11
    Nov 2016
    8
    Sst body changes
    Are all rc bodies interchangable ? What do I need to watch out for if I want to change my sst body for an aftermarket one ?
    Thank you!
    Nov 2016
    8
    Would tamiya bodys fit ? What specifications should I look for ?
    RC Qualifier IanRose's Avatar
    Oct 2016
    Boston South Shore
    449
    What kind of body are you trying to get? You need something with no more than a 6.5 inch wheel base, and I wouldn't go any shorter than 6.3. use https://latrax.com/products/sst?t=specs as reference for the wheel base and track width. Finding a competitor made 1/18 truck with similar sized dimensions could open up some options, but again, what are you looking for?
    Nov 2016
    8
    At this point something original. I'm not planning on competing or doing anything like that. Just mostly want it to look good and still be functional.
    Nov 2016
    8
    If I have 1/18 size would I be able to fit a 1/16 or even 1/10 body ?
    May 2015
    773
    Not a 1/10 that a pretty big scale change, a 1/16 might fit though it really just matters if the wheel hibs are in the same place and it doesn't go past the chassis. Also if the body posts will still be able to work
    Have Fun and Drive Recklessly
    Apr 2015
    124
    I like to buy the cheap hard body rc cars from Walmart and target. Lasts longer than lexan, immensely stronger, heavier for a more scale driving feel as well as appearance. Tough to size them up so there's a little trial and error involved. New bright 1:15 mudslinger Jeep Wrangler is a perfect wheelbase for sst but does require cutting and fitting.
    Nov 2016
    8
    Perfect thank you everybody
    Apr 2017
    Not to revive an old thread, but I just put a Dromida 4.16? (I think) body on my boy's SST and it was a little short bumper to bumper, but it fit and doesn't look too bad. I can attach a pic or two when I get home.
    RC Qualifier broitsseth's Avatar
    Feb 2017
    wherever i decide to be
    433
    ive done that before if you cut the rear bottom fenders off it looks pretty good
    cool ain't cheap -Dan Dreger
    Apr 2017
    The body is wider than the chassis so the rear wheels travel inside the fender and don't make contact.
    I'm sure I could have done it different, but I paid $7.00 for the body so I figured what the heck.
