Results 1 to 10 of 10
Thread: M41 Telemetry
    Jul 2012
    16
    M41 Telemetry
    I've added the Expander, GPS Module, Auto Sensor Temp, and Auto Sensor Voltage. Do they have a connector for the iQ plug to connect the volt sensor to it?
    Aug 2016
    127
    I believe you need part #6541 here: (scroll down)
    https://m.traxxas.com/products/model...41?t=telemetry
    I found this quite helpful:
    https://youtu.be/-26ZSgDqwQQ
    Jul 2012
    16
    thanks. I thought I had read somewhere that the connectors on the ESC had to be changed to first gen if you have the newer second gen plugs.. seems ez enough
    Aug 2016
    127
    I discovered you don't need the mount that you do for the Spartan. The telemetry expander pack fits conveniently between the motor and esc and bolts directly on to the removable electronics tray.
    I must say this is an excellent design - well done traxxas.
    Jul 2012
    16
    You are correct. It fits perfectly... so well played on the tray design. Great job all around for this boat. Love it!
    Mar 2016
    Colorado
    242
    The 6541 is the best connector for this or most other applications. I use it on my X-Maxx also.
    Aug 2016
    127
    Cool
    Quote Originally Posted by Rude98 View Post
    Yep it's an excellent design! I elected to switch my M41 connectors out for another brand so it is the same as all my RC's and my charger so I don't use the voltage telemetry.
    It's really just speed I'm interested in anyway
    Jul 2012
    16
    I got the right connectors to connect the Auto Voltage Sensor up correctly. Works as is should now. I want to make sure I'm not running close to the auto voltage cut off and be to far out. The lake is a little cold for a swim right now.
    Anyway... thanks for the help guys.
    Aug 2016
    127
    Quote Originally Posted by ntruder View Post
    good to hear! FYI the boat will still run when LVC kicks in, just slowly. Bring directly to shore and charge to storage mode you should be ok
    I also noticed the batteries heat up more as you get closer to LVC. I started with 5 min runs then gradually increased until I was getting warm batteries and that was my limit.
    Happy Boating!
    Jul 2012
    16
    yep.. it will limp back to shore.... It allows me to keep an eye on the voltage so I don't run into heat issues... I limit my runs as well so I don't puff any batteries. I already have a set of traxxas batteries that are starting to swell.
    Happy Boating to you too
