Results 1 to 14 of 14
    RC Champion jeteffect's Avatar
    Apr 2015
    1,756
    Bigger Tires for the Slash
    If you were to raise the ride height of the Slash 2WD, and have better handling in the some snow, what tires would you recommend?
    Photos welcome!
    Thanks!
    Oct 2016
    49
    Ive had good luck with the slingshots on the rear. Good tires
    Sent from my SM-N910T using Tapatalk
    Apr 2015
    1,756
    Quote Originally Posted by Superducky View Post
    Do you have a link or part number for these for the Slash? Wondering if they are bigger than stock and how they wear?
    Oct 2016
    49
    They dont wear well on asphalt obviously but they wear well in sbow and sand. I've had mine for a year
    Apr 2015
    1,756
    Is the Slash 1/10th got 17mm wheel hubs?
    Thanks
    Sep 2014
    539
    Quote Originally Posted by jeteffect View Post
    Thanks
    Stock is 12mm
    "Splash" ProLine Slash
    Rustler VXL
    Apr 2015
    1,756
    Quote Originally Posted by E-Power View Post
    Stock is 12mm
    Thanks for the note!
    Apr 2015
    1,756
    On slash 2WD do you install just two of these, rear? Or on all four tires?
    Also, do you recommend swapping tires on the stock bead lock rims, or have sling shots in separate rims?
    Thanks.
    Sep 2014
    539
    Thanks.
    You just need them on the rear and I would just get a set of pre-mounted. On the front you can run Mohawks or the stock, or even skis (see T-Bone Racing).
    Rustler VXL
    Apr 2015
    1,756
    Thanks guys.
    Do you have a pro line part number for the set that fits (tires on rims?) for the stock 12mm?
    Sep 2014
    539
    Thanks guys.
    The pre-mounted Sling Shot for the Slash 2WD rear is 1158-17. BTW, if you look at proline's site (www.prolineracing.com) for the Mohawk, there is a great video there of SCTs with Sling Shot and Mohawk set ups in sand.
    Rustler VXL
    Apr 2015
    1,756
    Thanks for the part number and reply!
    Are they direct bolt on replacement to stock 2WD Slash or any extra parts / adapters needed?
    Sep 2014
    539
    You may need to trim the body to fit the sling shots, or use adjustable body mounts (proline or rpm) to raise the body.
    Rustler VXL
    Feb 2016
    San Diego, CA
    264
    I was thinking of doing this to mine just because it looks cool:
    https://www.youtube.com/watch?v=o5aP2FozDSk
    Any drawbacks to the bigger tires?
