Results 1 to 32 of 32
    Sep 2016
    124
    Aluminum or Plastic? - Front Bulkhead 2530
    Hey to all,
    Over the weekend I wrecked my 2wd Slash and broke the Front Bulkhead (Traxxas part number 2530). From the looks of it, I'm assuming the impact site is at the right front wheel. Where one of the pins are inserted on the side is where the plastic broke. I had to take more parts off than I thought I would have to. This was just to get to the broken Bulkhead. To me it would make more sense to install the aluminum Bulkhead just in case the plastic broke again later. Also, I think one of the pins that goes through one of the side holes is bent as well. I'm assuming I'm going to have to at least replace one of the two pins.
    Is the aluminum a better choice? If so, should I look for a certain brand like RPM or another name brand?
    Thanks so much!
    Apr 2015
    779
    Get new pins, and just get the RPM bulkhead. It's a lot more durable than stock.
    Sent from my VS985 4G using Tapatalk
    Sep 2016
    124
    Is the rpm one plastic?
    RC Racer Jigsaw49's Avatar
    Nov 2015
    michigan
    214
    Rpm is plastic but it is super durable bendable plastic. I have a STRC aluminum bulkhead. It helps provide more weight at the front wheels which is helpful to keep them down on the ground and more turn in. I wound reccomend the aluminum.
    smooth is fast
    Sep 2016
    124
    Quote Originally Posted by Jigsaw49 View Post
    Can you tell me where you purchased the STRC? Also, is the RPM a plastic that does give/bend a little for durability instead of the hard rigid plastic?
    Nov 2015
    michigan
    214
    I got the Strc on amazon
    https://www.amazon.com/gp/aw/d/B005Q...MDL&ref=plSrch
    The strategy behind RPM is to provide some bend for more durability. Good for arms and hub carriers. Not for caster blocks and bulkheads.
    smooth is fast
    May 2014
    946
    This is something I wish I would of put on my lcg when I did it. Rpm will be more durable than stock for sure aluminum will be better off in the long run but will add a bit of weight to the front. Sometime on my wish list to do this winter is change the bulkhead.
    Sep 2016
    124
    As far as the 2 suspension pins, is there a better brand than stock?
    RC Champion Mr Wolf's Avatar
    Malmesbury, UK
    1,695
    Quote Originally Posted by stilllearning7 View Post
    Get some STRC polished hardened steel locking hinge pins. Combined with an aluminium bulkhead, the front end becomes super durable.
    Oct 2016
    4,240
    Quote Originally Posted by Mr Wolf View Post
    I was told by an old school hobby guy if you get the bulkhead too stiff your chassis will break instead of the bulkhead. That's the only reason I haven't gone that direction. And I haven't seen traxxas offer one. All my other aluminum is traxxas blue.
    Sep 2016
    124
    Could you give me the link for these pins? Also, these are the two pins that go on either side of the bulkhead? Called suspension pins also? Can I use my original end clips on these or do they send some with it?
    Thanks again.
    Malmesbury, UK
    1,695
    Thanks again.
    http://www3.towerhobbies.com/cgi-bin...&I=LXCSFD&P=ML
    This set replaces all the inner and outer hinge pins. They have locking nuts so can't back out on you.
    Sep 2016
    124
    Will the traxxas stock hinge pins be compatible with the strc aluminum bulkhead?
    Apr 2015
    nevada
    217
    The stock hinge pins will work with any bulkhead.
    Sent from my SM-G930T using Tapatalk
    Malmesbury, UK
    1,695
    Well, I think you received some bad advice. I run aluminium bulkheads in 13 trucks on this platform and have never once broken a chassis. I think a bearing carrier or arm would break before the chassis would at the bulkhead - I always keep these plastic.
    For me an aluminium bulkhead is the next most essential upgrade after alumininium caster blocks. The flex of a plastic bulkhead causes the inner hinge pins to bend very quickly from frontal impacts.
    Oct 2016
    4,240
    Point taken
    Oct 2016
    4,240
    Point taken
    I installed aluminum hubs because RPM was too sloppy
    RC Qualifier WonderMelon's Avatar
    Mar 2016
    Myerstown, Pennsylvania
    957
    I'd never listen to anything like that... Yes, less flex will result in snap snap but the bulk head won't break the chassis
    Oct 2016
    4,240
    So does traxxas make aluminum bulkheads.
    RC Qualifier spunkybob's Avatar
    May 2016
    600
    Are you racing or bashing?
    If bashing I say stick with RPM because aluminium can bend or break other parts if you land bad from a big jump.
    If racing then either or..
    I used to aluminium my RCs but never again because it just moved the break point to the next piece which could be a more expensive part to replace.
    I now have all the RPM parts for my 2wd slash and I beat the absolute crap out of my car and the only think that has broken was my skin when I ran I to myself.
    Sent from my SM-N930F using Tapatalk
    Oct 2016
    4,240
    Quote Originally Posted by spunkybob View Post
    I hit my foot and it was bruised for 2 weeks. I have rpm a arms and shock towers and bumper. This gives me the flex I need when I bash and does well speed wise as well. I have aluminum caster blocks and hub
    Carriers front and rear. I also have an Aluminum bell crank mated to a kimbrough servo saver hooked to a savox 1258 servo. I have glocs and trencher SC's to tell you what type of driving I do
    Edited for language abuse.
    May 2016
    600
    Yeah those parts in aluminium are ok because they don't "really" take the hits so its strength where strength is needed.
    Shock towers take a LOT of hits so I'd rather them bend and bounce back then bend and stay bent or snap the shassis plate!
    Oct 2016
    4,240
    Kind of my thought process as well
    Sep 2016
    124
    Well, if I wasn't lucky enough breaking my front bulkhead, I found out this morning that one of the caster blocks is also broke. Any suggestions on what to replace it with? RPM, Plastic, Aluminum? My STRC aluminum Bulkhead came in, and it looks nice, but I haven't installed it yet.
    Oct 2013
    62
    Id say alluminum castor block and steering block. Rpm plastic A arms
    Sent from my SM-N900T using Tapatalk
    Malmesbury, UK
    1,695
    IMO, STRC or TRX aluminium casters is a great way to go. For a fairly bullet proof set-up, run these with an STRC bulkhead and hardened locking hinge pins and RPM bearing carriers, shock tower and arms.
    Sep 2016
    124
    Any advice on thread locker for the STRC aluminum bulkhead that I purchased? I didnt think about it at the time? My LHS is more miles than I want to drive, but if I need to I will. Would a thread locker from Lowes Hardware be just as good? Thus far, the only piece that is aluminum is the bulkhead. I haven't purchased castor blocks yet.
    Feb 2016
    14
    Loctite blue 242 from lowes or any hardware.
    Jan 2017
    I'm about to install my new aluminum bulkhead for my 2WD Slash. Does it matter what thread lock I use or can I just get it from Home Depot ? Same question for the hardened A arm screws. With only 1 hobby shop for RC part within about 50 miles, they can pretty much charge what they want.
    Sep 2016
    124
    Personally, I wouldn't buy anything from Home Depot. I would recommend going to an auto parts store such as AutoZone, O'Reilly's, or even Wal-Mart and getting the blue threadlocker I think the number is 242 and it should say medium on it for medium strength.
    Jun 2016
    North Jersey
    659
    Loctite threadlock is the same no matter where u buy it....
    RC Racer h2rac3r's Avatar
    Dec 2016
    South Jersey
    223
    i broke the front bulkhead to and bent the suspension pins. i just replaced them with stock and haven't ruined it yet. i got another bulkhead if this one breaks hopefully it doesn't
