Thread: Drive train
    Oct 2016
    40
    Drive train
    Something is slipping between the engine and wheels it revs higher than it accelerates I tightened the slipper clutch and replaced the clutch shoes and it still does it, could it be the clutch bell? I think the problem is after the 2 speed gears because occasionally it will shift to second at a low speed which would suggest the transmission is spinning faster than the wheels so the only thing I can think of is the diff , can they slip a little bit without totally disengaging or locking up?turning the wheels by hand the differential feels like it's fine
    Marshal carraig042's Avatar
    East Tennessee
    6,774
    Did you sand/clean the inside of the clutch bell and make sure not fluids/glazing was present?
    -Brett
    4wd Sportmaxx 3.3
    13,648
    Agreed. Unless you broke a pin someplace down line or stripped a wheel hex. The differential does not have a clutch so it is direct drive to either or both wheels.
    Feb 2013
    Parker, CO
    1,390
    Clutch shoes backwards? Maybe pull the trans apart and give the one way roller a little drip of 3 in 1 oil?
    I have an RC problem...
    Dec 2006
    camillus, ny
    2,850
    Mine sometimes did this when the clutch got warm with the stock flywheel. It seems much better with the vented 40mm flywheel.
    Man i need more than 50 characters.
    Oct 2016
    40
    I think it was the clutch bell it was polished to a gloss from the old clutch slipping what grit sandpaper should I use? I've got everything up to 2000 grit
    13,648
    I've used 1000 grit.
    Oct 2016
    utica ny
    115
    i use a screw driver to scrap off gunk but i gently do this then i spray with brake clean and scrub with a wire brush, i also scrap off the spring when i remove the cb to help it stay clean.
    Everything dies..everything..no,no,no,no
