Results 1 to 16 of 16
    Dec 2016
    6
    Question Erevo tires on 4x4 Slash?
    Hi, noob here. Been reading the threads for quite a while, but haven't found an answer.
    Is there a taller/wider tire set up for the 4x4 Slash? Appreciate any feedback.
    Thanks!
    Josh
    RC Champion SlashMaxx4x4's Avatar
    Apr 2016
    Midwest
    1,006
    Welcome to the forums!
    You could go for any 2.8" tire, that would give you extra width and height.
    "Gone racing"
    Dec 2016
    6
    Thanks man! Is there a brand that you recommend? Would 3.8 be possible with a slight lift?
    RC Qualifier SlashSlayer4x4's Avatar
    Jan 2016
    NEW Denton, Texas
    362
    Quote Originally Posted by j1980mac View Post
    proline makes great tires, most will reccommend trenchers, some prefer badlands. 3.8 would be an extreme lift and add lots of weight, but im sure someone else will chime in soon. with bigger tires youll probably want to gear lower and upgrade your drivetrain
    Upgraded Slash 4x4 | 75+ MPH
    RC Qualifier NoobPlayer03's Avatar
    Sep 2014
    New Jersey
    259
    3.8"s will kill your drivetrain.
    Aww, SNAP. You crashed into the curb at 100mph.
    Apr 2016
    Midwest
    1,006
    Quote Originally Posted by SlashSlayer4x4 View Post
    Im a badlands guy, myself, and +1 on proline, good tires and a large selection.
    "Gone racing"
    Dec 2016
    6
    Good to know. If I went with 3.8s I'd be open to gearing it down a bit. Keeping in mind that I know nothing about RC, I think it could be a great combo with the Slash.
    Is it possible to get better than a 3s Lipo stock?
    Jan 2016
    NEW Denton, Texas
    362
    well assuming you have a vxl, 3s would be the absolute max. with 3.8s, youd probably overheat your motor rather quickly. even 2.8s get the stock system pretty toasty. i fried mine on 3s even with proline trenchers geared 12/54.. overall wouldnt reccommend 3.8s as theyre way too large. btw, going to 3s is when parts start needing upgrades.
    I have a 2200kv system now, and 4s is very hard to control, and pushes mine up to almost 75mph, so you probably want to stick to 2-3s. 3s is a completely different beast in this truck.
    Sep 2016
    San Diego, Ca
    323
    Like others said running wide MT 3.8's will lead to a range of possible component failures, you could probably get away with a narrower buggy type tire/wheel as the tire profile tends to be small and tires are where most of the weight and rotational mass come into play, the wheels themselves won't add alot of stress to the system. Ive ran 2.8 MT setups on stock components without an issue, just have to watch the temps of course.
    Jan 2016
    NEW Denton, Texas
    362
    what are you tryin to achieve by installing 3.8s? do you want the body higher, performance, looks, or what? if theres something in specofc you want, someone on here may be able to help you achieve it without puttin on tires that size...
    Dec 2016
    Illinois
    244
    proline is great
    Dec 2016
    6
    Hey guys, thanks for the discussion.
    I'm just trying to get into a car with budget in mind, (turning a Slash into an Erevo or Emaxx).
    I'm starting to think the EMaxx may be where I end up landing. After some consideration, I think the longer wheel base would make it way more stable than the Slash. I also like the Erevo, but it's like a cat on a tin roof.
    Jan 2016
    NEW Denton, Texas
    362
    protrac kit from proline will extend your wheelbase, so you may want to look into that
    Dec 2016
    6
    Are you talking about the Emaxx or Slash?
    Jan 2016
    NEW Denton, Texas
    362
    The slash. protrac kit extends wheelbase for slash, and is made by proline.
    Dec 2016
    6
    That changes things!
