    Jan 2017
    EZ Peak Dual Charger Issues
    Evening, I just purchased one of the EZ peak dual chargers and when I put two brand new batteries on it for storing. It seems like it never de charges. The 1a light and the green charged light are lit and thats all it does. Never seems to de charge and go into store. It seems to be charging fine.
    RC Qualifier Panamon Creel's Avatar
    Oct 2014
    Central Mexico
    427
    what's the capacity of the batteries you've connected?
    I'm assuming you've fully charged batteries connected and trying to discharge them to storage voltage, is that correct?
    20,556
    It's an 8 Amp, 100 Watt charger and 0.5 Amp, 4.2? to 6.3? Watt discharger. It will take a long time to discharge a large, full battery.
    Alt-248 on the number pad = °
    Jan 2017
    The batteries are new
    Traxxas LiPo 3S 11.1V 5000mAh 25C w/iD Connector
    Yes, trying to de charge for storage.
    Oct 2014
    Central Mexico
    427
    As ksb51rl mentioned above, the EZ peak Dual has a very low discharge amperage so bringing a fully charged battery down to storage level will take a long time. Better/faster to charge up to storage level than to discharge it to storage level.
    Jan 2017
    Dallas TX
    214
    Agreed, the discharge rate of the EZ Peak is way lower than the charge rate. Mine sat on Store mode for 4 or 5 hours the first time until I figured out you need to run the packs down in the vehicle and then place them on storage setting where they come up very quickly.
    "For we walk by faith and not by sight" 2 Cor. 5-7
