    Jan 2017
    Using two battery packs at once in 1/16 Summit
    I have fried one of my batteries before after installing it into my 1/16 Summit. I bought it off ebay so maybe it was just a bad batter. I'm using a parallel joint connector. I just bought two new batteries and want to make sure it does not happen again. Cant figure out how to post pics on here. My batteries are: Bias LiPo 2000mah 20c 7.4v 2-cell. I had to replace my chassis. Ive read that a series connector can be bad if you dont run it at high speeds and go slow.
    May 2015
    773
    Pictures dont work
    Have Fun and Drive Recklessly
    May 2002
    Midvale Utah
    1,773
    Quote Originally Posted by TrevorSingleton View Post
    There is no problem running slow or fast with a parallel or series connector. Unless it was damaged or built wrong, a parallel or series connector cannot damage your battery. A parallel connector is actualy easier on your batteries than running a single pack, because both batteries share the load, each taking half...
    Dacaur
    85
    Keeping your batteries balanced to each other could help them live longer.
    Some time ago I made a balance adapter that would charge both batteries at once and balance as one 4 cell battery.
    Photo hosting cred to RCGroups.com
