Results 1 to 20 of 20
    Aug 2016
    88
    How do you get these things clean?!
    Have a new Slash Platinum, and took it out on my track yesterday. It was pretty muddy, and when we were done, the inside of the Slash was FILLED with mud. With running water, I was able to get most of it out, but there is still a bit of mud in the cracks (bottom of the rear shocks, under the drivetrain in the honeycomb, etc).
    Any cleaning tips? Q-tips and toothpicks?
    Dec 2016
    104
    If you want to get that meticulous yeh toothpicks and what not... I just hose mine down really good then blow dry it with my air compressor... Also apply wd40 to the areas with bearings when dried...
    Sent from my XT1585 using Tapatalk
    RC Qualifier D4Jesus's Avatar
    Jan 2016
    Jersey
    369
    I usually just take the water hose to mine as long is waterproof u should b fine it should have a lil rubber gasket in the receiver box if so then u should be good
    Sent from my SM-G930P using Tapatalk
    Luv my slash
    Jan 2016
    Jersey
    369
    And if you've already run water over it then thats wut I'd do and since it's cold out where I live I just do it in the shower we have a removable shower head that works good 4 me
    Luv my slash
    Nov 2016
    New Jersey
    154
    I clean mine in the kitchen sink with the sprayer head. You can use scrubber brushes to get some the real caked up areas clean. Ive seen videos where they do it it bathtub. Traxxas video shows them using simple green and brushes. You are never gonna get it totally clean without pulling parts to get into tight areas. And def use wd40 on screws. I usually spray wd40 on a q tip and clean screws that way its less messy. Also get the bearings as best as possible.
    Jun 2014
    Southern California
    7,576
    Spray bottle with water, Simple Green, old toothbruch, air compressor, time, and patience!
    Aug 2016
    88
    Sounds like it's good enough. The Rustler is MUCH easier to clean. LOL.
    RC Champion shack351's Avatar
    Dec 2016
    Kville
    1,127
    I have a couple of Platinums too! They are great. As for cleaning, it depends how OCD you are! LOL! I shake mine a few times to remove any loose stuff, use compressed air to blow out grass, dirt, etc and then spray with relatively low-pressure water from hose or sink attachment. I use a toothbrush and pick to clean any built-up dirt and grime or to get into hard-to-reach areas. I then use compressed air to CAREFULLY blow out water and then let it sit out and dry. Last step is to spray silicone on most screws to keep them shiny! There is regular maintenance that you really should do as well, some of which is convenient to do at this time, but that's another discussion.
    RC Champion jeteffect's Avatar
    Apr 2015
    1,756
    Can't recall where I see it, but there is a video out there of a Slash owner putting it in a big sized bucket at the end of a run, holding it by front bumper, and throttling up for 5 seconds submerged. Washed it good!
    RC Qualifier jarod_rodriguez's Avatar
    Wake Forest, NC
    468
    Aside from all the great advice here, I take my cars and trucks completely apart once year. Everything, every screw etc. Do a full body inspection for worn parts, torn boots etc... I will soak all the bearing in Denatured Alcohol, scrub everything with soft brushes and get them degreased and clean and the reassemble and replace parts as needed. I typically do this in Jan/Feb when I have some down time. It takes time, but you also learn a lot.
    Lipo'd and Nitro'd - J-Rod
    Oct 2016
    65
    I just rinse with hose then I use dishwashing soap and brush it then rinse again. Then I hold the truck in the air and hold full throttle with the wheels off to spin the water out of the bearings. After drying it with paper towel, I spray the bearings with wd40. At this point the truck looks new. Then I rubb Vaseline on the whole thing to give it that " it's just been waxed look" at this point the truck looks nicer and cleaner than new lol.
    Dec 2013
    278
    Rinse and clean with a combination of water and/or simple green.
    Use a Wooster 2" stubby brush to clean out the dirt in the small corners. This works great to get into the small areas, much better than a tooth brush. $5 at Home Depot.
    Blow dry with an air compressor or my latest, is this Sidekick. I like the sidekick much better than an air compressor as it drys faster and warms the air a little (great for melting snow after bashing). Also useful when you wash your full size car or motorcycle, blows all the water out of the nooks and crannies.
    I also use WD-40 to displace water. I also use Maxima SC1 spray. Makes all the plastic look new and shinny. Also makes cleaning up next time much easier.
    [IMG][/IMG]
    Slash 4x4, E-Revo, Stampede 2wd (3 of them)
    Apr 2016
    Midwest
    1,006
    I use a hose and air compressor. Make sure to use WD-40 on the metal parts to prevent any rust.
    "Gone racing"
    Wake Forest, NC
    468
    Quote Originally Posted by explorerlyon View Post
    [IMG][/IMG]
    Digging the side kick. Where did you get from?
    Sent from my iPhone using Tapatalk Pro
    Dec 2013
    278
    Quote Originally Posted by jarod_rodriguez View Post
    Actually called Metro Vacuum Air Force Blaster Sidekick. Sells for about $75. You can buy it on autogeek.net, Amazon or other auto detailing places on the internet. It is made specifically to blow off the water from crevices on vehicles and motorcycles when detailing. Not something I would by just for RCs, but given you use on on your real vehicles also, well worth it.
    Wake Forest, NC
    468
    I am on the Raptor forum as well and always looking for detail tools to make my life easier. Thanks for the tip. Will be ordering ASAP.
    Apr 2015
    1,756
    Good advice and good fun!
    RC Qualifier spunkybob's Avatar
    May 2016
    605
    I used to pull mine completely apart (within reason) and wash all the parts by hand then put back together.
    Now I don't bother cleaning it because unless you are going to rebuild all the bearings each time there is nothing else that will care about the dirt because its mostly plastic.
    Once a year i just spend the $30 and buy a new set of bearings, but I have been know to clean out some of them and put new oil in every now and then.
    RC Qualifier RiderZ's Avatar
    May 2006
    Planet Earth
    419
    I stay out of the mud.Use 80psi air to blast the dust and debris out.
    Traxxas Slash Platinum Edition
    May 2016
    605
    Quote Originally Posted by spunkybob View Post
    I should mention i do give it a brush with an old paintbrush, but thats just to get rid of the lose big stuff.
    I make sure the drive shafts are debris free after each run, I am sick of replacing them.
