Results 1 to 17 of 17
    RC Qualifier broitsseth's Avatar
    Feb 2017
    wherever i decide to be
    433
    Question 550 motor and xl5 esc?
    putting an titan 12t 550 motor and xl5 esc in sst? not sure if possible before i tear it apart
    Feb 2017
    433
    im also using stock recever will it matter?
    Feb 2017
    Atlanta, Ga.
    46
    I don't think its possible considering the size difference between both the receivers and motors. Ive tried something like that before on a hellion 1/18 scale truck and all the gears stripped.
    Feb 2017
    433
    ive changed the truck to a dromida dt4.18 because of having a bigger chassie i've already fit the receiver and esc in it but im unsure ow i would mount the motor seeing that i have t make a new mount and i need a bigger pinion gear but really the only problem i the motor mount have any ideas?
    Dec 2001
    Everywhere man
    1,222
    Maybe cut out bottom of stock chassis to fit the Titan, but that is a big long motor so might not fit and then lots of weight on the motor mounting plate, might bend the plate. Maybe shuffle components around to fit, but I see you're trying to use dt418 chassis now, cut some aluminum to fit the mount spot, drill two screw holes to bolt motor on and one bigger hole for front of motor and shaft to fit through.
    Feb 2017
    433
    so ive began on the motor mount with a aluminum plate and now im lookin for a slightly bigger pinion gear then 23 tooth so the motor dosent rub on the driveshaft
    Feb 2017
    433
    im using a 7cell hump pack from a stampede and i have to mount it above everything else and the wheght makes it almost scrape lol
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMUN9
    im also using this motor because its a bit shorter then the titan
    Feb 2017
    433
    im getting close to completion just have to mount the battery and get a peice to connect the steering servo to the recever ill uplode pics when im done if i can
    Feb 2017
    433
    well darn... the motor mount i made just broke looks like i have to make a new one...
    i also found a diecast h2 hummer body i can fit on it anyone know of a way to make the shocks stiffer? i wonder if 1-16 scale sock would work?
    ill try to get pics this weekend if i have time
    cool ain't cheap -Dan Dreger
    Feb 2017
    17
    What esc and servo are you using to run that motor. Also what's the pro's about that motor.
    Feb 2017
    17
    Feb 2017
    433
    the esc i'm using is out of my (brushless but used to be brushed)stampede its an xl-5 and the steering servo is the one that came with the truck
    the servo:http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDVFJ(yes i know it discontinued)
    the esc:https://traxxas.com/products/parts/o.../xl5waterproof
    the motor is an titan 12t 550 motor i think every knows what that is
    Feb 2017
    17
    So the servo motor and esc all fit on the truck.
    Feb 2017
    433
    yes but with almost no extra room for a battery
    RC Qualifier IanRose's Avatar
    Oct 2016
    Boston South Shore
    449
    I've done some silly 1/18 experiments with 1/10 stuff before. Didn't take any pictures. Are you trying to make it work, or work well? You can, mount the battery up high. I ran a piece of plastic from shock tower to shock tower, put a full size 6 cell stick battery on top, and ran the body over that. It had a high center of gravity and little bit of a body gap. It was a 380 motor with a 1/10 esc and 1/10 battery, it actually ran really good, it didn't body roll that much but it was a lot more than stock form. The run time and amperage was great from the bigg battery. I feel like a 550 motor would drain a mini battery very quickly. would a mini lipo fit? good luck, keep us posted.
    How to Rc: Send them high, watch them die.
    Feb 2017
    433
    i'm going to try to get some pics tonight if not everyone will have to wait bc i'm going to be out of state all weekend(hope the 2wd pede olds up)
    Feb 2017
    433
    update:
    ive now decided to try to make this thing a bit tougher (broke the spur) so i'm getting this stuff:
    http://www.ebay.com/itm/Dromida-Alum...3D381935546622
    http://www.ebay.com/itm/Redcat-Part-...QAAOSw6kxXIT~g
    http://www.ebay.com/itm/Hot-Racing-D...IAAOSwcUBYHQsS
