Results 1 to 29 of 29
Thread: 60+ mph?
    Jan 2017
    St. Charles, MO
    24
    60+ mph?
    Currently I am running the 18T pinion and 54T spur in my Slash with a 2S LiPo. According to Traxxas that should be good for 40+ MPH, but I am only seeing a max of 39.6 on GPS (and 46 with the TLink RPM sensor)
    Will adding 1 tooth to the pinion (19T) and another cell to the battery (3S) really make a 20+ MPH difference in my Slash like the box says?
    RC Champion SlashMaxx4x4's Avatar
    Apr 2016
    Midwest
    1,006
    3S is a completely different animal than 2S, let me tell you that.
    Yeah, it'll make the 20mph difference if your battery is high enough mah and C rating.
    "Gone racing"
    SE Mass // Swansea MA
    140
    gotta git me one just for giggles
    Jan 2017
    St. Charles, MO
    24
    Quote Originally Posted by SlashMaxx4x4 View Post
    If the rating is telling the truth it's a 5500mAh, 35C. We shall see.
    Jun 2014
    Southern California
    7,685
    Keep a very close eye on your temps when "speed" running on your stock system.
    Nov 2015
    610
    Meh 4S is where its
    Aug 2016
    Seal Beach CA
    606
    3s is way way faster. Do you have a laser temp gun? It's a quick way to check temps between passes.
    Jan 2017
    St. Charles, MO
    24
    No laser temp gun, but I do have the Traxxas Telemetry installed so I can monitor the temperature that way. On my 2S it takes a while to get above 150, I am guessing 3S will be a little warmer.
    RC Champion jeteffect's Avatar
    Apr 2015
    1,760
    Will 30-35C 3S lips and 19/50 do it?
    Jun 2014
    Southern California
    7,685
    Remember, as per the manual...
    The included optional large pinion gear is intended for high-speed running on hard surfaces, and this gearing is not recommended for off-road or repetitive starting and stopping.
    Aug 2016
    127
    Quote Originally Posted by jeteffect View Post
    you should be pretty close but don't run it long - that could be overgeared
    Aug 2016
    Seal Beach CA
    606
    Mine is geared 18/50 and trust me it gets hot quick. No speed from those runs since it crashed before I could install the GPS but it was fast for a stocker. Tires Ballooned so bad they separated from the rim.
    Jan 2017
    St. Charles, MO
    24
    Yeah, I probably won't run it like this very long, it's almost too fast to handle at 40 MPH, I just need it to be faster than my neighbor's Stampede VXL 2WD. Every time he drives his he is pulling wheelies up and down our street and was just a little faster than my Slash with our stock trucks on 2S LiPo batteries.
    Apr 2015
    1,760
    Quote Originally Posted by Gunner1 View Post
    Wow! Which tires/rims? Stock?
    Aug 2016
    Seal Beach CA
    606
    Yeah the stockers. This was my first time with 18/50 gears. I did not have very good control of it and not enough room to let it wind out. I got 55 on this run. Next time out I killed it.
    https://www.youtube.com/watch?v=bqVWT8_bj0c
    New Jersey
    252
    I've experienced Flipping Over at speeds of 60mph. Had to put 8 ounces of weight up front. How about you?
    Apr 2015
    1,760
    Cool video! Like you said in that video, that's what I'm doing now; learning about speed runs and gearing, tire ballooning ahaha. Cheers and thanks for sharing.
    RC Champion Dcuda69's Avatar
    Jan 2015
    WI
    2,986
    Quote Originally Posted by 06redssr View Post
    Have to get the body as low as you can...some holes to vent the air will help as well. I have a 2700kv motor that I geared 20/54,stock body,stockish SC tires/wheels and hit it with 4s. It flew...literally...lol. Telemetry had it well north of 60mph when it went airborn....pretty spectacular crash on the street in front of my house,didn't think it would EVER stop rolling! Surprisingly nothing broke and I was able to give it another shot...same results..lol. Next time I try that stuff, I'll spend a little more time on body/suspension mods.....get it low so the air can't get under it.
    Slash 4x4 Ult 2150kv
    Rustler vxl
    Ford GT vxl
    New Jersey
    252
    Quote Originally Posted by Dcuda69 View Post
    I have my suspension set up for the street (very low) but still need weight up front at speeds over 60mph. I also have it raked so the back is higher than the front. I'm gonna try putting holes in the back half of the body for venting air.
    Apr 2015
    92
    Not knocking traxxas here. But as cheap as an ir temp gun can be had. I would NOT rely solely on telemetry for accurate results. Def mixed results in my camp of trucks. Both nitro and electric with telemetry.
    Identical tmaxxes telemetry temp readouts off by 5-7 deg. While the my ir gun says exact same temp when running the two on the same day and tuned correctly. Like I said. Not knocking traxxas here. But another method of temp measurement is very cheap insurance.
    20,536
    How much of a real world difference do you think the 5 to 7 F makes? A brushless motor can easily have two to three times that difference in temperature from one end to the other.
    Alt-248 on the number pad =
    Jan 2017
    St. Charles, MO
    24
    Well, my first adventure into 3S land was interesting to say the least.
    I wasn't able to do a true speed run as I was just in front of my house and a couple neighbors hard cars parked in the street. However, I was able to hit 50.2 according to my GPS, while the Traxxas Link application shows 76 MPH (I'm going with the GPS here)
    I think I need to wake up early Saturday morning and find a big parking lot to see if I can open this baby up.
    Apr 2015
    92
    Speed telemetry readings off that far from your GPS. Wow
    Jan 2017
    St. Charles, MO
    24
    Quote Originally Posted by Geeps1 View Post
    Yup, about 25MPH off from what I am seeing. I am pretty sure I have the model settings correct in Traxxas Link too.
    Feb 2020
    33
    Yes, I’m not sure what the s means, but it makes a world of a difference, my 1/16 slash is crazy fun with a 3s
    Dec 2016
    N Dakota USA
    708
    Quote Originally Posted by TimBobCom View Post
    If you are both running 2s and the stock VXL system, he should be a little faster than you on flat level ground. A 2Wd Stampede is lighter and has less drag on the driveline than a 4x4 Slash. But you on 3 s vs him on 2 you should be faster (gearing and tire size still a factor )
    Feb 2010
    Indianapolis
    14,327
    Let me ask you this. Did you record the run? If you did, you will see the constant speed. Just like a 1:1 automobile if the where loose contact with the ground it is going to show faster. My telemetry is close to spot on if you don't rely solely on the top speed reading it gives you.
    Jun 2014
    Southern California
    7,685
    That’s my guess as well... wheel speed/slippage (stock telemetry) vs actual distance traveled (GPS).
    FYI: OP has not logged in for almost 3 years...
    Dec 2019
    60
    I run 13/54 (stock) and have 3s Lipo stock vxl setup and go 55 top. It gets hot very quick though
