Results 1 to 17 of 17
    Jan 2017
    Dallas TX
    213
    What Tire Glue Do You Use?
    What do you guys find works best for gluing on new tires on your Summit wheels?
    "For we walk by faith and not by sight" 2 Cor. 5-7
    Oct 2011
    91
    Quote Originally Posted by Johnybravo View Post
    Are you using brand new, never used, wheels?
    If so just put it the tire on the wheel, and pull the bead away placing a few drops of glue release and go down the bead about every 1/8 of the way around putting glue.
    Now there is a ton of other threads on glueing tires, and that method I just said may be wrong. Look into other threads read them and go from there. That said I do my method and have no issues.
    Best of luck! If you have any other questions ask away!
    Dec 2003
    Dekalb, IL
    2,409
    I use losi's thin glue for my MT tires. Seems to hold up really well and not come loose. Dries ridiculously fast, so make sure you have everything lined up right or your going to end up with a messed up tire. Also, everytime I glue tires, I tend to always glue a finger or two together or to the tire. Do not be like me.
    Expert rigging at it's best!
    Jan 2017
    Dallas TX
    213
    That's a CA type glue? This is my first tire change so I want to do it right. Will be using the old wheels so I will need to de-bond the existing tires. Will clean the new tires with a de-greaser (Simple Green?) to remove mold release compound. I notice some guys online were using a big rubber band to hold the tire bead tightly against the rim while gluing. Any other tips are appreciated, looks like a pretty simple operation but you always learn something the first time around.
    RC Qualifier IanRose's Avatar
    Oct 2016
    Boston South Shore
    449
    I use dollar tree superglue. Its thick so it gives you time to get it straight on the bead. But It also takes longer to cure. It was strong enough to hold the tires on a 3.3 nitro revo. Some people tape their tires on the inside while they are off but I never liked doing that.
    How to Rc: Send them high, watch them die.
    RC Qualifier RCMad72's Avatar
    Dec 2016
    Hillbilly City, Texas
    323
    I use duratrax glue, it's made specially for tires (yes, I know it's just super glue) and I use the same process as Zach2600, place a drop about every 1/8 to 1/4 inch.
    if you fall, I'll catch you! - Your Floor
    N. Idaho... Da Sticks!
    7,614
    Here is a good tutorial on gluing tires. The video is for SCT tires, but the concepts are universal.
    https://www.youtube.com/watch?v=d0X_2GJI1Fw
    I use Losi tire glue, with proper prep, it has never let me down, and has a good working time to get the tire properly seated in the bead before it cures.
    Jan 2017
    Dallas TX
    213
    Thanks to all for the responses!
    Dec 2003
    Dekalb, IL
    2,409
    Yep. http://www.losi.com/Products/Feature...rodID=LOSA7881
    Oct 2016
    4,244
    Lol. Me too
    Riverton Utah
    5,642
    ^ Make me feel better that I'm not the only one...
    Yes, the Losi tire glue is great, you don't have to wait forever for it to dry. Ha ha ha that last part, too real man, too real. I'm utterly cursed when it comes to that.
    Is owning 27 RC's too many? No way!
    Jan 2017
    Dallas TX
    213
    Quote Originally Posted by RCMad72 View Post
    I just ordered some of the Duratrax CA tire glue from Tower Hobbies, is it pretty thin?
    Jan 2017
    Eastern Montana, USA
    49
    That's how I inadvertently threw a wheel at my spouse *d'oh!*..........her laughing at my dumb butt, me gesturing and saying that its not THAT funny --> broken lamp
    And I use dollar store super glue for beads; use a foam safe, rubber toughened for rips/tears. If you pay attention you don't need foam safe glue for doing beads, but doesn't hurt to have either!
    That's my 2 cents.
    Every crash/ broken story: This one time...
    Jan 2017
    Dallas TX
    213
    Well got the tires in and got them on, no sweat. The real question is how to get all of the old rubber off the rim easily, quite a bit stuck on there and had to be pried/cut out with an X-acto knife, was kind of a PITA.
    Dec 2003
    Dekalb, IL
    2,409
    Boiling them or baking them causes the glue to crystallize. Usually do that with the tires on the rim though so you can pull the tire to break the glue loose. I only do that when I'm trying to transplant tires. Rims are usually cheap enough that it isn't worth the headache. I had a ton of 3.2 MT tires on 14mm hex rims and needed to switch to 17mm.
    That was a long day... house smelled like burnt rubber for a few days. Only had a couple casualties where the tires ripped. They had been transplanted at least once already due to burned up hex's.
    A couple of my losi zombie maxx tires got the sides all bubbly because they were hanging over the cookie sheet a bit. I recently put them on 17mm RPM revolver rims and ran them on my ERBE in the snow. Balance is a tad off on a couple... but they did ok otherwise. I unmounted them 7 years ago.
    Apr 2016
    Midwest
    1,006
    I use AKA tire glue for mine.
    "Gone racing"
    Jan 2017
    Dallas TX
    213
    [QUOTE=olds97_lss;6366161]Boiling them or baking them causes the glue to crystallize. Usually do that with the tires on the rim though so you can pull the tire to break the glue loose. I only do that when I'm trying to transplant tires. Rims are usually cheap enough that it isn't worth the headache. I had a ton of 3.2 MT tires on 14mm hex rims and needed to switch to 17mm.
    [img]http://gmarquee98.x10host.com/myPics/98gmarquee/misc/2010
    Great tip, thanks!
