    Jul 2013
    Pembroke, Ontario Canada
    203
    Question Summit LT conversion Tire choices?
    Im doing a LT conversion to my summit and have a few questions.
    1. can i still run 17mm hex?
    2. Will 2.8 size tires work on the shorter slayer arms? without chassis rub? proline F-11 17mm part number #2755-03 https://www.prolineracing.com/wheels...eels-17mm-hex/
    3. Slayer A-Arms any weaker when cut to fit on summit bulkhead? im only doing trail runs not bashing with it.
    any other tips or tricks that may help?
    Traxxas 1/10 Summit, TRX4 Tactical
    -Marc Gill
    RC Qualifier MAC FAB's Avatar
    Apr 2014
    So Cal
    799
    Arms are weaker being trimmed, no doubt. However, seeing Matt's video of his LT being driven hard, I don't think I'd lose sleep for a trail application. I was even looking at aluminum arms. Have a second set of back up arms ready to go and you'll probably never need them. Cheap insurance. When mine is finished, its going to pull about 40 lbs and carry 15 lbs at the same time. I'm going with this insurance policy plan. As for tires, the width versus offset may cause you some grief with clearance, so be sure to measure twice and buy once! I'll be running rc4wd aluminum sc beadlocks with 12mm hexes. Baja Rey or Axial Score TT tires. 4-3/4"od if that helps for plan "B".
    Jul 2013
    203
    Finding the 12mm hex for slayer is becoming harder. I just I could use slash 4x4 hex's. I guess I could of said the wheel with verus tire choices. Got a link to matt's video?
    Ill do alot of measuring before choosing the wheel tire combo the 2.2 seams a Little small but I guess that's just me. Also looking at 1/8 buggy wheels which I know will fit. And are about the size of yeti score sct style wheels
    -Marc Gill
    Apr 2014
    So Cal
    799
    https://youtu.be/-zi5itLDcbc
    For some reason I can't embed on the Traxxas site. This: Traxxas Summit LT in Action -- Can Your Crawler Do This?
    Jul 2013
    203
    thank you for the link ill be ordering the parts today.
    -Marc Gill
    Jul 2013
    203
    i guess 2.2 fit easier than 2.8 i now see why. ill be attempting to find a roller and make this LT its own rig so i dont have to change the a-arms all the time.
    -Marc Gill
    Jul 2013
    203
    parts have arrived ye!!!!!!!!!!!
    -Marc Gill
