    RC Qualifier PecosBill's Avatar
    Apr 2017
    Illinois
    352
    Will the teton body fit on the sst without replacing the rear body mount?
    Traxxas stopped making the sst bodies and I realy need a new body So I was wondering if the latrax Teton body fit on the sst if I raise the rear mount all the way and lower the front all the way
    Jan 2017
    27
    The SST has a longer chassis than the Teton and Rally, so the wheelbase will likely not match. Perhaps if you get the Teton chassis, Teton upper plate, Teton driveshaft, and Teton body mounts, maybe it would work.
    Dec 2017
    3
    Or if your get the Teton body mount and drill holes... it wont look pretty but should work
    Apr 2017
    Illinois
    352
    The body mounts have the exact same space between the two sides that go into the holes on the Teton and sst
    I was wondering about how much the body would be behind the bumpers, and if it would look stupid.
    Doesn't need to be fancy. Just needs to run.
