Results 1 to 2 of 2
Thread: Battery drain
    Apr 2017
    13
    Battery drain
    I'm not sure if this is the right category, but I am having trouble with the batteries in my stock emaxx brushed. The low voltage detection light starts blinking red. If I unplug and plug back in it works for a while again but one of the batteries always charges longer then the other also. Is this normal or should I be worried about it? I usually get a decent run time out of it before it does it but I don't want to mess stuff up. Thanks
    Sent from my VS990 using Tapatalk
    Apr 2016
    24
    What type of batteries are you using?
    If you're using the stock Nimh batteries I would make sure that you have the Low Voltage Detection turned off. Low voltage detection is for Lipos and will shorten your run time if you have it on with the Nimh batteries.
