Results 1 to 17 of 17
Thread: Can it drift?
    Nov 2015
    21
    Can it drift?
    I am plAning on buying the GT when I comes out. As this is gonna be my first on-road and only owning a slash 2wd before this, I wasn't sure if it would be possible to use this as a drift style car. I know has 4 we which would help. But other than that I don't know what else it would need or if it is possible to do that in this car. If you have any ideas or know what would be needed to get or if it is even possible please post it. Thanks.
    RC Qualifier StampedeSwag13's Avatar
    Apr 2015
    544
    1/10, 4wd... yes. To some extent it can. You might want to add drift specific tires for better results though
    and RC pilots say RC cars can't fly!
    N. Idaho... Da Sticks!
    7,449
    From what I have seen, it can drift a little bit with the tires it has, but drift-specific tires would likely help it out a lot.
    Aug 2016
    Houston, Texas
    607
    i saw a video where the guy mentions some steering adjustment to make it drift better.
    RC Qualifier broitsseth's Avatar
    Feb 2017
    wherever i decide to be
    433
    heres a vid of it driving:
    https://www.youtube.com/watch?v=5_J5Pd1mWCI
    cool ain't cheap -Dan Dreger
    Apr 2016
    Midwest
    1,006
    A brushless motor would help too.
    "Gone racing"
    7,449
    Quote Originally Posted by SlashMaxx4x4 View Post
    We'll see. My plan is to run the stock system and see what it can do. After that I'll throw in the VXL I have sitting on the shelf, or get a CC 3800 system.
    Charlotte, NC
    605
    Go big or go home and get a 2400 system lol. I to plan on using a repurposed vxl system in it. I'm sure eventually people really will put a 2400kv motor in it and drifting should not be a issue. I'm also considering once the tires wear out to glue a piece of pvc pipe on just the rear tires to help with drifting the back end around. Won't be very useful in racing or normal driving but should add fun to it from time to time
    Stampede 4x4/Slash 4x4/Xmaxx/Alias/GT
    Nov 2015
    21
    Ok thanks for the information. I mainly plan as using this as an on-road "basher". I will look into some drift tires and buy some once I get the car. Would it help if I got a drift gyro or a service with a bigger turning radius? Thanks for the information so far
    Nov 2015
    21
    Service - servo
    RC Qualifier IanRose's Avatar
    Oct 2016
    Boston South Shore
    449
    I think it comes with a gyro... Isnt that what tsm is?
    How to Rc: Send them high, watch them die.
    Nov 2015
    21
    Yes your right now that I think about it.
    May 2017
    5
    Quote Originally Posted by aef2002 View Post
    It comes with tsm so the gyros might fight each other. It can also get the fixed plastic tie rods ands and camber links to adjustable and drift spec tires would definitely help even with a 7700kv and two cells it still hooks pretty good with that power
    May 2017
    8
    You can turn tsm off by turning the right knob on the controller to zero.
    May 2017
    Coruscant
    58
    I plan on picking up another one to use as a specific drifter. from what I understand all you need to do is mount the tie rod to the inner hole and trim off the little round nub off the steering arm stop. You'll also want top pick up 3 sets of turnbuckles to add some adjustability to the front and rear. Until Traxxas releases them you'll need a set @ 43mm for the tie rods, 45mm for the front uppers and 40mm for the rear uppers. As far as adjusting the ride height you'll need 4 set screws maybe m3 size ?
    akron oh
    107
    Anyone know where is a good place to get drift tires?
    Xmaxx, Summit, Villain ex, Aton, Alias, 4 tec 2.0
    Aug 2016
    Houston, Texas
    607
    http://www.hobbypartz.com/110car.html
    this place has a TON of drift tires. I have not tried them, but i did try their grip tires. the grip tires only lasted one battery before the tread wore off. but they are super cheap, and maybe drift tires would last longer.
