Results 1 to 16 of 16
    RC Qualifier lotust251's Avatar
    Mar 2017
    Long Island NY
    283
    Angry hinge-pins backing out of the A-arms
    hey guys, I'm sure this has been covered but I can't find it in the search (too many near results). but the rear hinge pins on both my stampede and slash 2wd keep backing out. I read that glue does not help. I see some possible solutions on google to where you replace the screw with a nut and bolt type. I usually only buy from www.rcplanet.com/ but I don't see my solution there.
    the pins now back out after running a single pack. Its annoying and seem to be common.
    also can anyone recommend another online vendor to buy all my parts from?
    edit: I think this is what I need
    https://www.rcplanet.com/Pro_Line_PR.../pro609600.htm
    thanks
    Shawn P
    Jan 2015
    VA
    97
    http://www3.towerhobbies.com/cgi-bin...&I=LXCSFD&P=ML
    towerhobbies.com and amazon.com are where I get most of my parts. If the link doesn't work, go to towerhobbies.com and in the search bar type in "slash 2wd strc". The hinge pins should be the first thing that comes up. I have them for my son's slash and don't have 1 complaint. He had the same issue your having before I got the STRC pins.
    Edit:
    Rc planet has them too but they are more expensive than tower.
    https://www.rcplanet.com/STRC_lock_n...trst3640bk.htm
    Mar 2017
    Long Island NY
    283
    Quote Originally Posted by Ric22 View Post
    Edit:
    thanks very much. Its weird that this problem only started happening after a few months. I guess it all loosens up and wears out. ohh well.
    Jan 2015
    VA
    97
    No problem. Hope they work well for you
    Jun 2016
    North Jersey
    660
    Put the stock pins in the opposite side of the arms on the ones that are coming out.
    Nov 2016
    Carrollton, TX
    285
    Quote Originally Posted by Blown94 View Post
    like put them in the front of the a-arm?
    13,563
    Are both sides backing out or just one? If one, then install it on the other side of the arm (you may need to remove the transmission to do so).
    I had the issue and screwed it in from the opposite direction. Then when I did the winter break maintenance I bought the STRC hinge pins.
    Jan 2009
    Great Britain
    1,034
    This is what i have done. Also a spot if suoer glue doesn't hurt.
    2wd Slash VXL, 2wd Slash 9t , E Maxx 2200kv ,Trx4
    Jun 2016
    North Jersey
    660
    Quote Originally Posted by toasterfree View Post
    Yes, on the ones that are coming out. Works like a charm. They are backing out with the suspension movement.
    Nov 2016
    Carrollton, TX
    285
    yeah i think i noticed that from my run on friday where i had one pop out. i looked at the other side that was mounted in reverse and hadnt moved
    Mar 2017
    Long Island NY
    283
    cool, I just reversed them (head of the screw faces forward ) None of them have moved now. thanks guys.
    Jun 2008
    wisconsin
    107
    mine also were backed out after every race on sunday, ordered the strc set, tired of messing with the stock ones
    Slash 2wd
    it is all about having fun
    Nov 2016
    Carrollton, TX
    285
    Quote Originally Posted by revocat View Post
    just turn them around so that the head of the pin faces the chasis
    Apr 2017
    161
    A drop of super glue on both ends fixed mine
    South of St Louis
    6,369
    When installing the STRC pins I had to clean up the plastic slots with a drill bit. I've forgotten the correct size. And if you use a drill be very careful and go very slowly. Only a single rotation or two is all you'll need.
    Jul 2016
    Houghton, MI, USA
    97
    I have just been re-tightening them when they back out... This has also striped a set of button heads that hold some of the chassis together.... I may look into a nut and bolt set if I have to take everything apart again...
    2wd Slash with upgrades.
