    Mar 2017
    16
    Gearing for bashing/speed
    Hi All,
    I have a pede 4x4 vxl. I am running the 11/54 stock gearing with a 3 cell lipo- truck hits 50Mph- I ordered
    The 15 tooth pinion to run with the stock 54 spur gear. Is this safe? I have a esc fan
    And a motor fan. I am looking for a higher pinion gear setup for an extra boost for bashing and speed runs -good combo
    Any suggestions?
    Dec 2003
    Dekalb, IL
    2,192
    Odds are your going to overheat. Mine thermaled out on me running 2S with 14/54 after 30 minutes of running. I didn't have fans though, but if it got hot enough on 14/54 and 2S to shut down, odds are your going to overheat it if you aren't already.
    Expert rigging at it's best!
    RC Qualifier JohnnyHildo's Avatar
    Jan 2015
    Canada
    747
    you are only limited by motor heat with the vxl. this is the reason traxxas recommends only using "speed run" gearing on the road and with attention placed on the temps a lot more often then you'd like.
    sl4sh 2200 / p4de 2400
    RC Qualifier Bige4u's Avatar
    Jan 2017
    Texas
    427
    You can go as low as using a 9T pinion and still acheive 30mph+ with your current setup for bashing... temps should be more than atequate for your needs.
    Bashing along @ 30mph...
    Mar 2017
    11
    I installed the 9T pinion on mine when I was running the 2s. I just installed the 3s and with the 9T, it's plenty fast for me on road and works well off road.
