Results 1 to 15 of 15
    Oct 2016
    4,231
    Bought Lemouds Roller
    Bought a roller with 2.8 trenchers. I've got the TQI setup along with the VXL setup. The truck needs some bearings and a slipper shaft. Couple odd and ends. Got a prograhics body, and an 11/54 gearing setup. Just learning the truck. Figured the best way was to tear it apart. Also had big bores lying around.
    Any help or advice appreciated.
    I will say Briber has been a big help so far.
    Apr 2017
    Chicago burbs
    80
    Making good progress already!
    RC Qualifier Bige4u's Avatar
    Jan 2017
    Texas
    427
    Looks pretty clean for a roller... i almost went that route because i wanted to build a p4de my way, i was hoping to find the VXL version new, but none could be found, so i decided to get the rtr XL-5 truck brand new out of the box and converted to brushless right away along with other hop ups.
    Bashing along @ 30mph...
    Dec 2015
    St. Peters, MO
    3,329
    My pleasure my friend, ☺. What springs are those? I like the blue color! And welcome to the P4de family 😉.
    92.5 mph Rustler (Rusty 1.0 R.I.P.)
    78 mph on 4s/93 on 6s(Rusty 2.0)
    86.9 mph Stampede 4x4
    Apr 2016
    Midwest
    1,006
    Gripdog, is this one going to stay a basher? Or can we expect another speed rig soon?
    "Gone racing"
    Oct 2016
    4,231
    Some integy springs from fleabay. Red is lighter than the blues. Blacks were too tight.
    This is definitely a basher, and will stay that way. A guy gave me some skateboard ramps.
    Oct 2016
    4,231
    It's functional. Got a few odds and ends to tidy up but I'm pretty happy so far. Lots of work, but it's paying off
    Dec 2015
    St. Peters, MO
    3,329
    Since its going to be a basher and you mentioned ramps, do you have aluminum caps on shocks? If not Id get them before you jump or else youll be constantly popping off the plastic ones...
    Oh and if your wanting to jump, the stiffer the spring the better jumps/launches youll have. I used the yellow integy progressives when i jumped. They were super stiff...
    Jan 2017
    Texas
    427
    Those plastic camber links wont help either.... converting to adjustable turnbuckles will be prefered.
    Apr 2017
    Chicago burbs
    80
    Definitely agree on those aluminum caps!! My little dude blew 2 plastic caps off in about 5 minutes on the new-to-us vxl pede. We were only hitting our little 8" tall plastic ramps too.
    He's still trying to adjust to jumping 4x4 vs the 2wd. They definitely jump a bit different and have a tendency to drop the nose. I'm gonna try upping the fluid viscosity in the rear shocks and see if that helps. Maybe go to a one hole piston...?
    With that said, these things take an absolute beating and keep coming back for more.
    Oct 2016
    4,231
    I put big bores on it. 45wt. Oil. Three hole Pistons. Big bores lived previously on the Rustler. I haven't run it yet so we shall see. I see some aluminum steering components in my future.
    Oct 2016
    4,231
    Quote Originally Posted by Bige4u View Post
    I've got em up front. Need a set for the rear. I was trying to use up my spare parts.
    RC Qualifier czlynx's Avatar
    Jan 2016
    459
    My son still has the plastic ones on his truck... Can't seem to break them! I know they're not adjustable but they have proven to be durable.
    Oct 2016
    4,231
    Took the truck out when the rain stopped. The bearing on the output of the rear diff(the one I didn't get) is crunchy. Loud and affecting performance, it's creating a drag. Bad part is I knew it was and couldn't stop building the other night. Geared 11/54, it's good for a beginner to 4x4. The only thing I broke was an axle(already suspect). So I had a fwd truck. Not fun. Replaced the axle and was doing wheelies and scooting all over the place. So I need axles and a bearing(s) to make this more reliable. It's gonna be fun, I think.
    Dec 2015
    St. Peters, MO
    3,329
    For now pop out seals, spray bearing out, grease or oil, put seal back in.
