Results 1 to 8 of 8
Thread: Fiesta st rally
    May 2017
    33
    Fiesta st rally
    Hey guys just picked up this new rally an seems fun but needs adjustments.... I'm thinking the a arms need wider for one as camber adjustable links as well. From there it's shock set up. Then maybe gearing. Any one familiar with this new rally and what improvements have you made. 1/10 version !!!!
    Sometimes you have to turn right to go left !!
    Mar 2019
    11
    Hi there, I have the Ford fiesta rally as well. So far I've upgraded the motor mount, the driveshaft down the middle, put a slipper clutch in and upgraded to the venellion motor ECU combo. Unfortunately I cant seem to get the gear mesh correct. But up until then I can honestly say I love this car.
    Jan 2019
    94
    Traxxas support has a gear mesh video ...
    Apr 2018
    20
    I think you need to purchase a 32p pinion to match the spur of the slipper clutch.
    I observed the spur on the slipper clutch is much agressive 32p instead of the stock one with 48p
    I bought the valineon 3s combo with new pinion and slipper clutch. I'll see how everything fits together pretty soon
    Jul 2019
    Blaine MN
    Hello all, I new to the chats but not rc .I picked up the fiesta a few months back and absolutely love it. I've upgraded to rpm rally arms essentially widening it to a slash, dropped a hobbywing xerun xr8 sct 140amp esc, with a 4300 kv motor . 17mm strc adapters, gpm onroad tires. I put steel turnbuckles all the way around. I only run 3s so i upgraded to 54t spur 15tpinion 32p. i also did the strc bellcrank with bearings. might try to mod the posts so i can add a little stability without going with aluminum.
    Feb 2016
    4
    I have the Brian Deegan Fiesta Rally car. So far I have upgraded the lower arms, front steering and caster blocks, rear carriers and front and rear axles. I also upgraded to a castle sidewinder motor and ESC combo. I went with the Differential upgrade vs the slipper. I believe they are both 32P so a new pinion is needed. You can use the Slash 4x4 gearing chart to figure out what pinion you want to run.
    Nov 2019
    DMV
    15
    Hey guys!
    I built my Traxxas Rally from spare Slash 4x4 parts and put a Hobbywing Max8 combo with 2200kv motor. Running 6S lipo with traxxas 5000mah 25C 50 burst. I also put aluminum Integy A arms on it and aluminum Hot Racing bellcrank with adjustable servo saver. I installed Integy aluminum motor mount and Integy aluminum front and rear bulk head. With this I can keep the car down when running. I also, installed proline adjustable body mounts. And far as gearing I am using Mod 1 34T spur and 24T pinion. I added a dual motor fan from MxFans from Amazon. I put some Hoons tires on there from the Arrma Infraction and they work really nice with Hot racing 12mm to 17mm hex adapters.
    Finally, installed some Hot Racing sway bar links with red in the front and blue in the rear. Red is softer and blue is medium. Silver would be harder. Still playing with that setup. Other than that I'm looking for affordable batteries that are at least 35C or higher. Here is a picture of my build setup. Any suggestions are welcome. New to the hobby since September 2019.
    Nov 2019
    DMV
    15
