Differential problem/upgrade
Whats better than the stock rear and front differentials on the e revo brushless edition 1/10 i want to upgrade them any ideas?
Highly recommend get all L.E.M parts http://store.leadingedgemachining.ne...ory-s/1832.htm and aluminum diff housing, cup and bearings. I used this Hot Racing RVO11MX01 diff housing, TRB RC 6x13x5mm Precision Ceramic Ball Bearings YE Hybrid Seals for pinion. TRB for other Bearings. So far have had 0 problems with it accept for the Hot racing diff cup problem. https://traxxas.com/forums/showthrea...LEM-diff-gears https://traxxas.com/forums/showthrea...ff-cup-problem
What gears do you recommend?
L.E.M http://store.leadingedgemachining.ne...-p/lem-238.htm for the rear.
The front you don't have to worry about to much, just get the Revo 1/10 Diff Cup V2 Combo Set or buy them separately.
If you've got an ERBE just shim the diffs right and run the slipper slightly loose so it will just wheelie and you'll be just fine.
I used to run big joe 2's and a tight slipper and had diff problems. Went back to stock wheels and no problems with 6s. About 30 hours run time since and no issues.
- You may not post replies
- You may not edit your posts
Forum Rules
