Results 1 to 30 of 30
    Jun 2017
    11
    Question Rustler: the throttle doesn't work, but the wheels turn
    What do I need to do to be able to get my Rustler up and running again? I am kind of new to this hobby. I have been around it before but am just now starting to work on them.
    RC Turnbuckle Jr. jvogel's Avatar
    Oct 2010
    PM me if you want to bash near Grass Valley, CA
    3,144
    I am more than willing, and quite capable, of helping you but I'm not really sure what you are saying. There are too many possibilities to cover without more information. Will you please elaborate?
    Obstacle Magnet
    RC Qualifier Myrustlervxl's Avatar
    Dec 2016
    Ohio
    500
    Sound like you might be in lipo mode when your trying to run a nimh or vice-versa
    Sent from my SM-G930P using Tapatalk
    Good work isn't cheap, cheap work isn't good
    Dec 2016
    Ohio
    500
    What color is the ESC light? Solid red light is for nimh and solid green light is for lipo
    Jun 2017
    11
    Whenever i turn the car and remote on, the throttle doesn't work, so the car will not move but, the wheels turn. And i am currently charging my batteries to see make sure that isn't affecting it at all. My dad thinks that there is something wrong in the motor because nothing will rotate or turn in there.
    Dec 2016
    Ohio
    500
    I don't think there's nothing wrong with the motor. what color is the light on the ESC and what battery are you trying to run? Is the ESC light flashing? Or solid one color?
    Jun 2017
    11
    7 cell 8.4 volt brand: Racer's Edge 5000. Can you help me understand what the ESC light is so that i can look for it? Is it the light on the motor or the one next to the button where you turn it on?
    Dec 2016
    Ohio
    500
    Esc is the box you turn on with the button
    Dec 2016
    Ohio
    500
    When you turn it on it should be red not blinking just solid red
    Jun 2017
    11
    When the car is still, the ESC light is solid green, but when it moves it flashes greens. But, I think that's because it blinks each time I move the throttle or something like that.
    Dec 2016
    Ohio
    500
    Ok now we're getting somewhere turn the car on when the light is green hold it down for about 10 seconds until you hear a beep and then the light will turn red you should be good to go
    Dec 2016
    Ohio
    500
    https://youtu.be/FCNsmV18PSg
    Jun 2017
    11
    When the car is still, it is solid green
    RC Champion lektro's Avatar
    Nov 2016
    Virginia Beach/ South USA !
    1,922
    So in other words you are trying to run a NIMH battery in lipo mode. Solid green Silly ! push the on button on the ESC and hold it till you hear a tone. Should go to solid red for your type battery. I know this has already been said but the more the merrier!
    Choose Life !!!
    Dec 2016
    Ohio
    500
    I think he got it running now.
    Jun 2017
    11
    Thank you so much!!!! I will go try it right now
    Jun 2017
    11
    I just turned the light to red, and only the steering will work and the throttle wont work.
    Dec 2016
    Ohio
    500
    Try this. https://youtu.be/ix-J85uRFjE
    Jun 2017
    11
    Ok, I will give it a try and let you know
    Jun 2017
    11
    I tried the video you sent me, and I followed the steps with each light blinking exactly like the video said it should and it still wont do anything but turn the wheels.
    RC Turnbuckle Jr. JerrysMaxx's Avatar
    Jul 2014
    NAWLINS
    3,952
    Quote Originally Posted by Bbucy30 View Post
    Am I reading correctly the wheels turn? is this when you throttle it with the wheels off the ground
    T/SportMax/Slayer Pro/Bandit
    Stampede/Rustler
    Jul 2014
    NAWLINS
    3,952
    Is this an XL-5 or VXL model?
    Stampede/Rustler
    Jun 2017
    11
    The wheels are on the ground and no throttle, just turning the wheel, the wheels only turn. This is and XL5 model
    Jul 2014
    NAWLINS
    3,952
    ok after reading through this thoroughly in my opinion there is nothing wrong with your esc, battery or such.
    The truck would still move in Lipo mode just will not run long before lvd kicks in.
    Couple things to check would be if the motor is working. To check disconnect the leads from the esc to motor apply direct power from your battery to the motor and see if motor spins. If it does make sure the slipper clutch is tight (snug the nut and back off 1/8 to a 1/4 turn). If that is set right, check the mesh between the pinion and spur gear. Last and not what I hope is the input shaft pin, shouldnot be able to turn shaft from spur while holding the wheels from turning.
    Stampede/Rustler
    Jul 2014
    NAWLINS
    3,952
    unplug the red and black motor leads and touch them to your battery
    Stampede/Rustler
    Jun 2017
    11
    Quote Originally Posted by JerrysMaxx View Post
    The motor will not spin.
    Jul 2014
    NAWLINS
    3,952
    sounds like your motor is done
    Stampede/Rustler
    Dec 2016
    Ohio
    500
    Well your dad was right. Now it's time to upgrade to brushless
    Oct 2010
    3,144
    Wow, I was right. Myrustlervxl, you can either buy a new Titan 12T or upgrade to brushless. I say just get another Titan 12T. They are so cheap, they are throw away.
    http://www3.towerhobbies.com/cgi-bin...&I=LXNMM6&P=ML
    Obstacle Magnet
    Dec 2016
    Ohio
    500
    Wow I did not know titan 12T was so inexpensive. My son is still runs his 12T but he has a castle creation sct 1/10 under the bed for a future. But for $15 he might get another titan 12T.
