    Aug 2016
    Houston, Texas
    607
    Rear Diff Binding
    the other day i noticed there seemed to be a lot of oil or grease coming out of my right-rear axle where the diff housing is. last night i went to swap out the rear diff with an XO-1 diff (it was perfect fit on the front, so now time for the back).
    so when i was re-assembling the rear, i noticed that if i tighten the right-rear screw on the housing, it would make the spur very hard to spin. i put the stock diff back and had the same issue. i think it must have come from the box with it slightly loose to keep it free-spinning.
    if i loosen the screw, it seems to work fine, but there is a slight gap on the diff-housing now, and it causes the grease to come out. i put marine grease this time, so maybe it will stay put, but i was wondering if anybody else has experience a similar issue...
    i will try to get some good picture of what i am talking about when i get off work.
    cheers.
    RC Champion lektro's Avatar
    Nov 2016
    Virginia Beach/ South USA !
    1,922
    Sounds as if something is not seated properly. I just looked at all the specs looking for teflon washers that may have been misplaced but didn't even see any in the parts list or exploded views. I have put them below to maybe help you out.
    https://traxxas.com/explodedviews/Fo...assis-Assembly
    https://traxxas.com/explodedviews/Fo...Front-Assembly
    https://traxxas.com/explodedviews/Fo...dular-Assembly
    https://traxxas.com/explodedviews/Fo...-Rear-Assembly Good luck
    Choose Life !!!
    Aug 2016
    Houston, Texas
    607
    I think it was some grit or dirt that got in there from when I switched out the diff. I did a good cleaning and it seems to be much smoother.
    RC Racer SilentRunner007's Avatar
    Dec 2015
    NJ
    196
    I seem to have some leakage at my left front output and mine is still bone stock.
    3RusterXL5
    4Nitro4Tec
    "Snap On"Alias
    Craniac
    Nov 2016
    1,922
    Quote Originally Posted by SL4SHGT8BASHER View Post
    Glad you got it all figured out. Thanx for letting me know.
    Choose Life !!!
    Jul 2017
    Kemah
    Did you get both diffs installed? Any driveshaft/axle shaft changes? Iv'e done quite a few differential swaps for the Revo and Slash 4x4s before.
    Aug 2016
    Houston, Texas
    607
    i did. i tried "locking" the front with super thick grease, but it did not work. i have an HR diff locker on the way. the XO-1 diff are probably super overkill because of how little this car is, but i don't mind...
    LA
    415
    Aug 2016
    Houston, Texas
    607
    http://m.ebay.com/itm/Hot-Racing-Tra...%257Ciid%253A1
    This is the one I was looking at. Probably good either way...
