Results 1 to 25 of 25
    Dec 2016
    21
    Aftermarket wheel help please?!
    Hey, I'm looking at a new set of wheels but I'm unsure which will fit correctly due to needing a bigger offset for the portals. I don't really want to run bead lock wheels so is there any others with the 11mm offset that is needed out there? I'm looking at rc4wd White 8 spokes in the deep dish form as they're 12mm offset. I just wondered what other people are using? Any help would be great. Cheers Rob
    Jun 2013
    346
    Dec 2016
    21
    Thank you!
    Do you think these would fit?
    https://www.ebay.co.uk/itm/122414016550
    Jun 2013
    346
    Sorry I do not kow
    Traxxas Employee
    Aug 2013
    Dallas
    445
    You might need to drill out the center hole slightly. Those only have a 4.2mm opening. It will likely hit on the axle unless you drill it out a little. The hex actually sticks out further than the wheel so clearing the portals is no issue. It's going to give you a really wide offset. They have a huge inner wheel opening though. Why not go with a better offset unless you are trying to widen the track as much as possible?
    Dec 2016
    21
    Thank you for the reply e-maxx dude. I do like the normal version of those wheels they're not so wide. Maybe you can check them out for me? Only 9mm offset though.
    https://www.ebay.co.uk/itm/110975984951
    Traxxas Employee
    Aug 2013
    Dallas
    445
    Those don't use a hex, but rather sit on the pin itself. They would likely be harder to fit.
    Dec 2016
    21
    You can get hex adaptors for them, would they work otherwise? Kinda have my mind made up on them. Haha
    https://www.ebay.co.uk/itm/132061507883
    Traxxas Employee
    Aug 2013
    Dallas
    445
    I would say that's a better option. You will still likely need to drill out the center axle hole.
    Dec 2016
    21
    So the 9mm offset isn't anything to worry about for clearing the portals, this was my main worry. Is the actually width ok?
    Traxxas Employee
    Aug 2013
    Dallas
    445
    As long as you have 39mm inner clearance on the wheels, you will fit over the portal axles, regardless of offset. Those have more than enough to clear the portals. One set of wheels I've used have 38.5mm and they just barely clear them.
    If you do need to drill out the center hole, just make sure to use a drill press and do it properly. If you drill it out off-center with a hand drill, your wheel may wobble.
    Dec 2016
    21
    It says wheel width 25mm or 1 inch, I guess that's no good?
    15,607
    My ssd scale trail 1.9 scale trail beadlocks fit. Confirmed today at hobbytown
    Ya can't polish fertilizer...
    Oct 2016
    67
    might want to doublecheck.. i have ssd's as well, and they fit on the axle just fine. then i took a good look at the backside and noticed the hex wasn't seated fully into the wheel. sure enough, the wheel wasn't fitting over the tapered part of the axle. went on far enough to get the nut on so i didn't think about it.
    drilled out the openings and now they sit nice and flat on the hexes like they're supposed to.
    Feb 2013
    Andover Township, NJ
    308
    I like the SSD DOUBLE TIME's. They have a little different specs. Will these wheels fit with out any problems??
    Traxxas Employee
    Aug 2013
    Dallas
    445
    They don't list an inner wheel diameter. You can always make them work because they use SLW hubs which come in many offsets. They may not look right with a really big offset though.
    15,607
    Quote Originally Posted by ubernewb View Post
    Nope bolted on and fully seated on the hex. The wheel I list above has hubs that fit over the tapered part. I seen on rcc that some ssd wheels come with different hubs
    Dec 2001
    Everywhere man
    1,222
    Quote Originally Posted by trxrincon View Post
    Yes, the RC4WD stamped steel beadlocks will work, just buy the hex adapters for them! I've used RC4WD Wagon wheels with six lugs and they fit great, just had to use the hand drill and enlargen the hex center hole slightly to fit them all the way onto the drive hexes on the axles.
    Dec 2001
    Everywhere man
    1,222
    Yes, SSD stamped steel that come with Wraith style hexes fit right on, the other style hex has smaller hole in middle and took me 5 minutes to drill out a set of four including a coffee break. I've found that RC4WD wheels are stronger though.
    Dec 2016
    21
    It's the drilling that scares me! They're an expensive set of wheels to mess up, I dunno if I'd trust myself! Haha
    RC Qualifier lotust251's Avatar
    Mar 2017
    Long Island NY
    283
    I'm going this route. Pro-Line Hyrax 1.9" G8 , Gmade 1.9 SR02 Beadlock Wheels GMA70176
    https://www.youtube.com/watch?v=Teu1G9-an9M
    Slash, Stampede,Craniac,X2 TRX4 ,ford gt 4 tec 2.0
    Dec 2016
    21
    Quote Originally Posted by Natedog View Post
    Please correct me if I'm wrong but it's just the hex adaptor I'd drill not the actual wheel itself?
    Traxxas Employee
    Aug 2013
    Dallas
    445
    That depends on the wheel. If you are using a standard width hex, enough of the axle will poke through that you may need to drill out part of the wheel. It's a 6mm axle, but it tapers down at the end. Some RC4WD wheels I've seen only have a 4.2mm axle opening. Those would likely need a little drilling.
    Dec 2016
    21
    It's the 8 spoke " wagon" wheel I want to use. Cheers
    Dec 2001
    Everywhere man
    1,222
    Quote Originally Posted by E-Maxxdude View Post
    That depends on the wheel. If you are using a standard width hex, enough of the axle will poke through that you may need to drill out part of the wheel. It's a 6mm axle, but it tapers down at the end...
    X2
    I've mounted those on mine, just used hand drill to carefully drill all four wheels hex adapters.
