    Aug 2015
    30
    NiMH batteries cut off / on
    When running full speed motor will "stall" for a second or two.
    Any idea why the power is being interrupted?
    Happens several times in a 3 to 5 minute run starting with a fully charged battery.
    Battery is about 2 years old and charges to proper voltage.
    After run motor 140, ESC 120 (has fan) and batteries 140 to 160 degrees. Motor is Brushless 3500 Velineon, ESC VXL-3s. Air temp about 90.
    15,348
    Stock battery? At 160 that's pretty Flippin hot. Sounds like the motor is pulling more amps than the battery can provide. 2 years old+5 min runs+ super hot battery is telling me 1 thing... bad battery
    Ya can't polish fertilizer...
    15,348
    Stock battery? At 160 that's pretty Flippin hot. Sounds like the motor is pulling more amps than the battery can provide. 2 years old+5 min runs+ super hot battery is telling me 1 thing... bad battery also motor that hot after 3 or 5 min you may be overgeared? What spur/pinion do you have installed?
    N. Idaho... Da Sticks!
    7,959
    Yup, a NiMH above 120*/f is bad.
    Have you constantly ran the pack until the truck can no longer move?
    Oct 2010
    3,149
    More RC math:
    Quote Originally Posted by rjm1cc View Post
    After run...batteries 140 to 160 degrees..
    = danger
    Obstacle Magnet
    Aug 2015
    30
    Thanks
    Is their any tests that would let me know the batteries are going bad?
    I charged and ran the battery again. Toward the end of its run life I lost steering and power control. The fan in the truck was still running. Turn off ESC and back on and truck ran. Any idea what caused this?
    On Lipo batteries I do not have a problem so as noted above the battery is probably at the end of its life.
    Oct 2010
    3,149
    rjm1cc, it's been so long since I have even seen a NiMHpack! If you got that pack as hot as you said, I'd discharge it and safely dispose of it post-haste. The real potential danger outweighs any possible benefit in keeping it for even one second longer.
    Obstacle Magnet
    15,348
    Is the esc in lipo mode?
