    Oct 2013
    268
    Long travel rockers, but the shock must be adjusted to bottom to pull the truck up
    Hi.
    I have a mini revo with summit wheels and pink summit springs.
    Just mounted long travel rocker, but when i press the truck down it stuckt there.
    So i had to adjust the adjust washer on the shock all the way to bottom on the shock.
    Now it bump up to top if i press the truck against the table, but it is very short and little suspension this way with the adjuster on the shock pressing the spring to mutch together.
    Any suggestions?
    May 2002
    Midvale Utah
    1,773
    The Rockers don't affect anything other than the total amount of travel you get. Sounds like you just need stronger Springs try blue or purple
    Dacaur
    Oct 2013
    268
    Yes, Appriciate your help.
    Will try both blue and purple
    May 2002
    Midvale Utah
    1,773
    i run purple rear, blue front....
    Dacaur
