Results 1 to 18 of 18
    Jun 2016
    152
    Body flies off easily. Any ideas why?
    So the body seems to fly off fairly easily. I mean a very light flip over still has the body flying off. Almost seems like the roll cage or retaining hooks are too soft. Nothing seems to be broken either. Any thoughts on how to improve this? Thanks.
    Feb 2017
    140
    Replace them
    Sent from my SM-G950U1 using Tapatalk
    May 2017
    82
    Mine has never came off. Tore the body away from the cage but that's all
    Eastern Shore, Maryland
    2,772
    Look at how your body's front mounting hook, and your body's rear turn clamp come in contact with your trucks chassis. You can see both by looking though the wheel wells of your truck. If you don't see anything obvious, then I'd take a ride down your LHS and compare your truck's mounting contact areas to a new one. If you still don't see anything obvious, I'd think about getting a new body mount system for your body.
    Beeville Texas
    235
    My body flys off all the time. I've replaced bodies, and all mounts. Anyone come up with a fix for this?
    RC Champion rizz0d's Avatar
    Jan 2002
    1,053
    only real fix is to quit crashing
    mine's weird. sometimes i can have a super gnarly crash and the body stays on, and sometimes it's a super light tumble and it pops off. just depends on how it hits i guess.
    rizzodtheRCvlogger - www.youtube.com/user/rizz0d
    Oct 2015
    471
    Quote Originally Posted by timritchieblue View Post
    Reinforce the body with Shoe Goo and FibaTape. My videos have details of how I did it to mine. Strengthening the body prevents it from happening. My truck had taken big hits in my videos and the body stayed on each time. I am running an 8S X-Maxx now and I have tumbled like crazy at speed without any issues.
    My X-Maxx, Rustler, Aton, and XO-1 fly!
    Feb 2016
    444
    Is the body reinforced with anything? Stock I could see it being able to flex and pop off. I have mine reinforced with hurricane tape. I like to jump my xmaxx pretty hard and I've never had the body pop off.
    Edit: jumpfly posted as I was typing haha. I agree, just reinforce the body.
    Beeville Texas
    235
    My stock body was reinforced with goo, and tape, and flex steel. I thought it was too heavy, so I replaced with a new body. Same results,, then replaced entire latch/mount system. Same results.
    Can't destroy a body if won't stay on.
    Feb 2016
    444
    The only thing that will make a body detach from the chassis is flex. There isn't much to it. I use hurricane tape to reinforce my body. Not sure if that would help you more than what you used before.
    Oct 2015
    471
    That is pretty weird. Do you have a video showing a time the body came off. I am interested in seeing how you are hitting hard enough to knock the body off. Also, how tight is the body latch on your truck?
    Oct 2015
    471
    Well, since I bought my 8S X-Maxx used, I finally pulled the screws through the front of the body. I kind of sensed the holes looked a little deep from what I remembered from my 6S truck, but my guess was right when I went to do some bashing yesterday. Sure enough they pulled through. After I put the washers around the screws I will post in here if the body pops off again. Luckily I had a spare shoe lace from a friend's shoes on hand so I tied the body to the cage and was able to get through a few hours of bashing (even though the body kept coming off).
    Feb 2016
    444
    Quote Originally Posted by drivejumpfly View Post
    Yeahhh my screws pulled through the hood of the body the second time out driving mine haha. I fixed it with putting a piece of plastic underneath the holes then going over it with shoe goo and drywall tape. Then purchased a set of these for on top. Very nice washers. They even recess down in to the screw holes on the stock body.
    https://m.ebay.com/itm/BLACK-Recesse...%257Ciid%253A4
    Sep 2016
    103
    Here's my solution. Drill a hole, put in a dowel or could even use a body post off another RC, then pin the dowel. Before I did this I used Velcro on the bottom side of the shock tower and on the top side of the tounge from the cage that slides under it. This works ok but wares out quick from sliding the body on and off. This suggestion/solution is just my solution, I'm certain you guys can find something better, getting the cotter pin in is difficult for big hands. I leave the rear unlatched and put the pin in from the back, if your hands are small you can reach in from the front.
    I did this because the body would come off from impacts and hard landings. Not a big deal unless the body comes off when you land and then it continues to roll or cartwheel exposing the chassis and electronics to damage which the body does a great job of protecting. I have noticed that a new body and roll cage are less likely to come off vs a worn out body and cage.
    Sent from my SM-G925T using Tapatalk
    de oppresso liber
    Nov 2016
    32
    I have a cheap idea. Yes the body comes off from the body-support and body flexing to much allowing the tounge to come out from underneath the shock tower. Here's the solution, attach another support from tounge to the lock, I used half inch pex pipe it's strong, lightweight and cheap. I have pictures if anyone would like to post them for me. This is a very effective way to keep from poppin the top.
    Beeville Texas
    235
    I would like to see a picture? I’m using a 500 mm Velcro strap on the front mount wrapped around bumper mount.. might just sell truck, I have 2 new UNBREAKABBLE bodies, can’t test.
    Oct 2015
    471
    Quote Originally Posted by XmaxxSmash View Post
    Here are your pictures:
    Beeville Texas
    235
    Thank you for the pictures, had to google PEX PIPE, I’ll give it a go. Need to find a solution, because I don’t even drive my truck because of body flying off issue.
    Seems like a lot of people are in denial about their body’s flying off,,,it happens ALOT
