Hey anybody use this mod the slipper clutch eliminator in a slash 4x4 ,please let your comments about it!!
Hey Chino,
Yes, I have used this one. It is a solid piece but be forewarned that going this route is going to abuse your drivetrain more than any slipper ever will. I do like it tho, just not for day-to-day use. When testing it out on my CC MMX/2200Kv sensored setup, it "felt" different. It was actually cool because after driving with the slipper for so long around the same area, when I was driving in that same place with the slipper eliminator, I could tell when and where it was "slipping" before with the slipper clutch installed. To keep it simple, yes, it drives the wheels all the time and you will feel a difference in most cases.
-Shack
Thanks so you say its better use not always in order to protect drivetrains !!
Don't put one in, you'll start breaking spurs, driveshafts, etc.
youtube.com/c/RazorRCvideos
Hey Chino,
Yes, that statement is factually correct. However, at least in my experience, that is not always the case. If you are willing, and able ($$$), to upgrade other parts, then you can have a beastly rig! Another thing to take into consideration is what size batteries you'll be running and what motor. If 4S or less, parts breakage directly caused by the slipper-eliminator will be few. With a stock Velineon, I seriously doubt that you would ever break any of the parts listed below. Now if you start adding a more powerful 10th-scale motor or even an 8th-scale motor (), you will need better parts. There are other "stress points" to plastic (bulkhead, diff housing) that may require more frequent replacement, but this stuff is cheap and I personally would not let it be a deterrent. I like to change it all around (slipper/no-slipper, different spur/pinion, 3S/4S/6S, etc, etc) just for the fun of it!
I have spent some dough though and bought many complimentary parts to "harden" my drivetrain.
For example:
Aluminum Diff Cups (STRC & LEM both rock!)
Fully hardened cup internals, F & R - Spiders, Outputs, I-Bar, & Shaft (by LEM)
Hardened Mod-1 pinions & spurs
Tekno Driveshaft
MIP X-duties all around
HR or KHZ motor mount (with larger bearing)
17mm hexes (a good idea to add but maybe not a necessity)
Ceramic bearings (low priority but nice to have)
With these mods, there is still a weak-link or two. The ring & pinion (diff case) is not hardened and I have not found a replacement that is for the front and rear. HR does make a spiral-cut gear that I have yet to try. I am going to see what I can do about hardening the stock Traxxas ring & pinion. Not sure if it's the right type of metal though to do much good.
The bottom line is this. It is a cheap part to buy and if you don't like it, discontinue using it. I like it sometimes because I like the full power to the ground. If my 5th-scale, CC 2028 rig can take it, yours can too!
-Shack
I use one in my speed truck and always recommend them to speed builds.
slash 4x4 168mph
youtube:philip jolley
Speed yes. Bash no.
IG: @818sFastestRC
Slash 4x4 138MPH
