Results 1 to 25 of 25
    Apr 2017
    Tampa FL
    101
    What did I just do ElSob win
    Ill let a photo do the talking. I'm sure I will have my hands full with this add on.
    Sent from my LG-H872 using Tapatalk
    Jun 2014
    Southern California
    7,542
    Time to have fun and grinning ear-to-ear! Congratulations!
    Apr 2017
    Tampa FL
    101
    Only concern is how to mount the useless switch.
    Any ideas for a wheelie bar?
    For anyone wondering, its the ElSob classic funny car motor, Mamba Monster 2 esc, and 2 5000 mah 2s lipos.
    Other mods include, 20% stronger springs on stock shocks, XO-1 differentials front and rear, MIP xDuty axles front and rear, proline trencher tires, and Velcro battery hold down, stock main gear, 18 tooth motor gear.
    It was already fast on 3s why not try 4s, or 5s?
    Jun 2014
    Southern California
    7,542
    Just cut the switch off and solder the wires together.
    RC Qualifier SlashSlayer4x4's Avatar
    Jan 2016
    NEW Denton, Texas
    363
    Quote Originally Posted by Wjs82 View Post
    RPM makes a wheelie bar, and so does traxxas. I run the RPM wheelie bar with the traxxas wheels (they have bearings and actual rubber). I have a 2200kv setup, and one more thing you'll need is 17mm adapters, I personally run hot racing 10mm offsets. Have fun!!
    Upgraded Slash 4x4 | 75+ MPH
    Apr 2017
    Tampa FL
    101
    Quote Originally Posted by SlashSlayer4x4 View Post
    I know mip makes a 17mm adapter but I dont think I get a choice off offset?
    Jun 2014
    Southern California
    7,542
    Apr 2017
    Tampa FL
    101
    You use these with the mip axles?
    Dec 2003
    Dekalb, IL
    2,368
    They key to the 12mm MIP hex like a wheel does, then the inner hex nut holds them onto the axle and gives them some support. I've looked at those too since I run the MIP's that have the slotted shafts vs a shaft with a hole in it for a pin.
    Expert rigging at it's best!
    Apr 2017
    Tampa FL
    101
    Ah, got it. Thank you for the clarification. I wont have 17mm wheels till my prolines smooth out. Then ill be on to some terrain crushers.
    Jun 2014
    Southern California
    7,542
    I have run both the 6 and 10mm offsets on my basher with MIPs. No problems with either set.
    Aug 2015
    Australia mate...
    159
    Order Traxxas part no. 5626, its a mamba monster esc mount and has a spot for a switch. Its only a few $$
    Indianapolis
    14,175
    Congratulations! You have just made a huge step up in performance! You are going to notice an immense gain in power while running cool. I am happy for you
    Apr 2017
    Tampa FL
    101
    Gotta give it to the guy who started it. Thank you for trying the odd combo to make it easier for us.
    The best part about the motor and esc is I have 130 bucks invested. Love me some eBay.
    Apr 2017
    Tampa FL
    101
    These look like they are splined but not all 17mm rims are. Is that a concern I should have. I just melted a wheel off my truck so the upgrade is needed.
    RC Champion Dcuda69's Avatar
    Jan 2015
    WI
    2,953
    Those will fit any 17mm wheel...splined or hex
    Slash 4x4 Ult 2150kv
    Rustler vxl
    Ford GT vxl
    Apr 2017
    Tampa FL
    101
    Quote Originally Posted by Dcuda69 View Post
    Any idea the offset to fit the terrain crushers. The ballooning is just hilarious
    Dec 2003
    Dekalb, IL
    2,368
    Curious how it does with the jumps. Mine with a smaller 1/10th scale system and a 7200mah 2S pack slaps the ground pretty hard. I'm running relatively stiff springs with 80 or 90 weight oil in the shocks.
    I'd have to guess running 1/8th scale electronics and the extra weight for 2x2S or 1x4S really makes it land hard. Or do you not hit much big air with these when setup this way?
    Apr 2017
    Tampa FL
    101
    I launch it threw the air like I want to break it. I have stiffer springs and stock oil. It handles it like a champ so far. Other than destroying the stock axles I havent had to fix anything else.
    I have installed xo-1 differentials, and mip drive shafts. Other than that I never ever take it easy, full throttle or no throttle!
    Dec 2003
    Dekalb, IL
    2,368
    That's surprising. Mine hits the ground so hard that it flexes the chassis enough to drive the pinion into the spur and ruin the spur. The mesh was fine before and after the landing, so the motor wasn't sliding, the chassis was bending. The last 2 spurs I ruined were after installing the king headz motor brace/mount. I was running 70w oil at the time. I think I'm running 80w now and I also got the traxxas heavy duty motor plate in hopes that it removes some of the flex.
    Apr 2017
    Tampa FL
    101
    Mine for 80% of its life has had the 2.8 trenchers and that really keeps the body off the ground. In fact I set the suspension at max compression so the body can't contact the ground.
    May 2017
    332
    Nice rig I have the same motor I have hobby wing esc tho I'm about "done" with it. Like what u did have fun!!!
    Sent from my SM-G900V using Tapatalk
    RC Racer SlashServices's Avatar
    Apr 2016
    169
    Quote Originally Posted by Gdude1057 View Post
    Mm that looks absolutely beautiful! Looks like a complete blast!!!
    Sent from my Pixel using Tapatalk
    May 2017
    332
    @slashservices thx man!!
    Apr 2017
    Tampa FL
    101
    Lost another tire yesterday and guided her in at full speed into a Cadillac escalade tire. It moved the motor and broke the Lipo straps from whatever company I bought it from. So reset the motor mesh, put on new tire and back on the road. Ive been stupid lucky, haven't destroyed the body or frame parts.
